23054 Discussions
Der Versuch die automatische Treiberaktualisierung auf die neuste Version 19.6.26.3 upzudaten schlägt fehl.
TAnon
Anstatt zu installieren wird vom Installationsprogramm nur eine Deinstallation angeboten. Auch nach Durchführung der Deinstallation (der Vorgängerversion) bleibt es dabei - es wird weiterhin nur eine Deinstallation angeboten!
TAnon
The attempt to update the automatic driver update to the latest version 19.6.26.3 fails.
Instead of installing, the installer only offers an uninstall. Even after performing the deinstallation (the previous version) it remains there - it is still offered only an uninstall!
Leonardo_C_Intel
Hello TAnon
Thank you for posting in the Intel Community.
I understand that you are having problems to uninstall and update Intel® DSA on your system, can you try the following:
•  Uninstall the existing Intel® DSA tool in the system with the Uninstaller tool (https://downloadcenter.intel.com/download/28598/Intel-Driver-Support-Assistant-Uninstaller).
•  Download and install the latest Intel® DSA version from (https://downloadcenter.intel.com/download/28425).
By the way, what is the brand and model of your system?
Hope this helps.
Leonardo C.
TAnon
Thanks Leonardo.
1. I have started the uninstall tool, DSAUninstaller.exe Vers. 19.2.8.7
DSAUninstaller.log:
Restarted as administrator. New process id is 6348
Stopping non-elevated process
Beginning DSA Uninstaller
GetBundleGuid() start
Did not find Bundle Guid _bundleGuid =
GetBundleGuid() end
GetOrphanedProductIds() start
GetOrphanedProductIds() end
GetOrphanedEntries() start
GetOrphanedEntries() end
GetOrphanedClsIdEntries() start
GetOrphanedClsIdEntries() end
Uninstalling DSAService
DSAService not installed on this computer
Uninstalling DSAUpdateService
DSAUpdateService not installed on this computer
Uninstalling SurSvc
RemoveService failed to uninstall SurSvc with exception: System.ComponentModel.Win32Exception (0x80004005): Der angegebene Dienst ist kein installierter Dienst
  bei System.ServiceProcess.ServiceInstaller.RemoveService()
  bei DSAUninstaller.ProgressBarVM.RemoveService()
Uninstalling ESRV_SVC_QUEENCREEK
ESRV_SVC_QUEENCREEK not installed on this computer
StopTray() start
StopTray() end
Uninstall() start
Uninstall() end
CleanRegistry() start
Deleted Registry Key: CurrentUser\Software\Intel\Intel Driver Update Utility
Deleted Registry Key: LocalMachine\Software\Intel\SUR\Installers\QUEENCREEK
Deleted Registry Key: LocalMachine\SYSTEM\ControlSet001\Services\DSAService
Deleted Registry Key: LocalMachine\SYSTEM\CurrentControlSet\Services\DSAService
Deleted Registry Key: LocalMachine\SYSTEM\ControlSet001\Services\SurSvc
Deleted Registry Key: LocalMachine\SYSTEM\CurrentControlSet\Services\SurSvc
Deleted Registry Key: LocalMachine\SYSTEM\ControlSet001\Services\ESRV_SVC_QUEENCREEK
Deleted Registry Key: LocalMachine\SYSTEM\CurrentControlSet\Services\DSESRV_SVC_QUEENCREEKAService
Deleted Registry Key: LocalMachine\Software\Microsoft\Windows\CurrentVersion\Run\DSATray
CleanRegistry() end
CleanProgramFiles() start
CleanProgramFiles() end
DSA Uninstaller has finished
2. Then I have started the installer, Intel-Driver-and-Support-Assistant-Installer.exe Vers. 19.6.26.3
but it didn't install....
Leonardo_C_Intel
Hello TAnon
Can you provide me with the Intel® DSA log files located in C:/ProgramData/Intel/DSA?
Leonardo C.
TAnon
the contents of the log file was already copied in my last post 🙂
please find the file enclosed
Leonardo_C_Intel
Hello TAnon
Thank you for the information that you have shared. Could you provide me with the Intel® System Support Utility for Windows* report?
·        The TXT file the Intel® System Support Utility will generate: https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility
·        Steps to save the report:
1-   Run the utility.
2-   Click on “Scan” to get the scanned system.
3-   Once the scan is complete click on “next”.
4-   Use the “save” option, save the report to your desktop.
5-   To attach a file, you must click the “Attach” option on the bottom left-hand corner of the response box.
Leonardo C.
TAnon
Hi Leonardo,
please find the attached file ssu.txt
Leonardo_C_Intel
Hello TAnon
Thank you for the details of the system. Allow me to investigate the behavior that you are having, I will be posting back as soon as possible.
Leonardo C.
Leonardo_C_Intel
Hello TAnon
Thank you for waiting.
Could you run the Intel® DSA uninstaller and the Intel® DSA installer to collect the following log files from C:\Users\{user}\AppData\Local\Temp
Intel®_Driver_&_Support_Assistant_20190701090653_000_DriverSupportAssistantInstaller.log
Intel®_Driver_&_Support_Assistant_20190701090653.log
Leonardo C.
TAnon
Hello Leonardo,
two files enclosed
Leonardo_C_Intel
Hello TAnon
Thank you for the LogFiles let me review the new information. I will be posting back as soon as possible.
Leonardo C.
TAnon
Hi Leonardo,
what did your research reveal?
Since the installation program offers only an uninstall instead of installing, probably remains (folders, file or reg.-Entries) of the previous installation are present.
If one could identify them, then a manual deletion and subsequent reinstallation would be possible?
TAnon
now the new version: Intel-Driver-and-Support-Assistant-Installer 19.6.26.4 could be installed.
