22657 Discusiones
Difference between 20.19.15.xxxx and 15.45.16.xxxx graphics drivers
PAkiv
Principiante
13.812 Vistas
I was about to update my Intel HD 530 when I noticed that the drivers in the downloads website was from a different series than mine. The websites lets me only download 15.45.16.xxxx drivers while I have 20.19.15.4474 version. I am not sure if it would be a good move to do it because if I remember correctly I initially installed that version because of massive flickering problem I had, which was solved after that driver was install. Do you think I will have any problems if I go on to install the 15.45.16.xxxx drivers?
0 kudos
3 Respuestas
Stefan3D
Colaborador Distinguido II
11.655 Vistas
Check out:
Empleados
11.655 Vistas
Hello PeriAkiva,
I understand you would like to know the difference between 20.19.15.xxxx and 15.45.16.xxxx graphics drivers.
Let me apologize for any inconvenience this issue may be causing to you.
The following link will give you information about Intel graphics driver version number http://www.intel.com/content/www/us/en/support/graphics-drivers/000005654.html http://www.intel.com/content/www/us/en/support/graphics-drivers/000005654.html
Let me know if you have or not any other inquiry.
Fred
Empleados
11.655 Vistas
Hello PeriAkiva,
I was wondering if you have or not any other inquiry about the Intel® Graphics Driver Version Number. If you have any other question just let me know.
Fred
Responder
