22690 讨论
Display Driver has stopped responding and has recovered
员工
135,392 次查看
Hi. I know this question has been asked many times, but many are unanswered. I have a Dell Inspiron 1545, Window 7 64 bit. Just yesterday, my laptop kept blacking out, freezes and then unfreeze and this message would pop up saying, "Display driver stopped responding and has recovered. Display driver Intel Graphics Accelerator Drivers for Windows XP(R) stopped responding and has successfully recovered." It keeps happening around every 15-30 minutes. Sometimes, it totally blacks out. Other times, it unfreeze but the windows are blank. Someone please help me. The display adapter I have is Mobile Intel (R) 4 Series Express Chipset Family." Some people said online to update it and that might fix the problem. I went to the Intel website and updated the lastest one given, but the problem is still here. I've restored my laptop to a certain restore point, but still did not solve the problem. Suggestions and ideas? Thank you a head of time.
451 回复数
MGard5
初学者
5,052 次查看
Sir Nic do I have to uninstall my video driver before installing this driver that you gave ? thanks
0 项奖励
MGard5
初学者
5,052 次查看
Thank you for the help Sir Nic ... I will just observe my PC if theres an improvement.. Thank you again and God bless.
0 项奖励
MGard5
初学者
5,031 次查看
Hi Sir Nic, the driver that you gave is working perfectly .. finally there's no error occured in my driver accelerator after a few days of observing.. thanks to you Nic I will let you know if the problem come up again,, but now Im happy for the improvement of my PC .. Thanks again
0 项奖励
KEhle
初学者
5,031 次查看
Hi Nic,
So my computer didn't like the driver you gave me. I attempted to install it and it came up with a window that said: "The driver being installed is not validated for this computer. Please obtain the appropriate driver from the computer manufacturer. Setup will exit."
Any other suggestions?
Lady Thyme
0 项奖励
mroe
初学者
5,036 次查看
i have also same problem my system showing this message
"Display driver Intel Graphics Accellarator Driver for Windows 8(R) stopped responding and has successfully recovered "
And My dxdiag report is the following
System Information
Time of this report: 7/13/2013, 18:14:45
Machine name: ROELT-PC
Operating System: Windows 7 Home Premium 64-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_gdr.130318-1533)
Language: English (Regional Setting: English)
System Manufacturer: CLEVO CO.
System Model: W150HRM
BIOS: BIOS Date: 06/17/11 16:09:17 Ver: 04.06.04
Processor: Intel(R) Core(TM) i7-2630QM CPU @ 2.00GHz (8 CPUs), ~2.0GHz
Memory: 8192MB RAM
Available OS Memory: 8098MB RAM
Page File: 3246MB used, 12950MB available
Windows Dir: C:\Windows
DirectX Version: DirectX 11
DX Setup Parameters: Not found
User DPI Setting: 120 DPI (125 percent)
System DPI Setting: 120 DPI (125 percent)
DWM DPI Scaling: Disabled
DxDiag Version: 6.01.7601.17514 64bit Unicode
DxDiag Notes
Display Tab 1: No problems found.
Display Tab 2: No problems found.
Sound Tab 1: No problems found.
Sound Tab 2: The file WsAudio_DeviceS(3).sys is not digitally signed, which means that it has not been tested by Microsoft's Windows Hardware Quality Labs (WHQL). You may be able to get a WHQL logo'd driver from the hardware manufacturer.
Sound Tab 3: The file WsAudio_DeviceS(4).sys is not digitally signed, which means that it has not been tested by Microsoft's Windows Hardware Quality Labs (WHQL). You may be able to get a WHQL logo'd driver from the hardware manufacturer.
Sound Tab 4: The file WsAudio_DeviceS(2).sys is not digitally signed, which means that it has not been tested by Microsoft's Windows Hardware Quality Labs (WHQL). You may be able to get a WHQL logo'd driver from the hardware manufacturer.
Sound Tab 5: No problems found.
Sound Tab 6: The file WsAudio_DeviceS(1).sys is not digitally signed, which means that it has not been tested by Microsoft's Windows Hardware Quality Labs (WHQL). You may be able to get a WHQL logo'd driver from the hardware manufacturer.
Sound Tab 7: The file WsAudio_DeviceS(5).sys is not digitally signed, which means that it has not been tested by Microsoft's Windows Hardware Quality Labs (WHQL). You may be able to get a WHQL logo'd driver from the hardware manufacturer.
Input Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (retail)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: Intel(R) HD Graphics 3000
Manufacturer: Intel Corporation
Chip type: Intel(R) HD Graphics Family
DAC type: Internal
Device Key: Enum\PCI\VEN_8086&DEV_0116&SUBSYS_15001558&REV_09
Display Memory: 4047 MB
Dedicated Memory: 1999 MB
Shared Memory: 2047 MB
Current Mode: 1280 x 1024 (32 bit) (60Hz)
Monitor Name: Generic PnP Monitor
Monitor Model: DELL E196FP
Monitor Id: DELA015
Native Mode: 1280 x 1024(p) (60.020Hz)
Output Type: HD15
Driver Name: igdumd64.dll,igd10umd64.dll,igd10umd64.dll,igdumd32,igd10umd32,igd10umd32
Driver File Version: 9.17.0010.3190 (English)
Driver Version: 9.17.10.3190
DDI Version: 11
Driver Model: WDDM 1.1
Driver Attributes: Final Retail
Driver Date/Size: 6/5/2013 19:54:13, 12615680 bytes
WHQL Logo'd: Yes
WHQL Date Stamp:
Device Identifier: {D7B78E66-4256-11CF-E97E-0D35B4C2C435}
Vendor ID: 0x10DE
Device ID: 0x0DCE
SubSys ID: 0x15001558
Revision ID: 0x00A1
Driver Strong Name: oem64.inf:Intel.Mfg.NTamd64:iSNBM0:9.17.10.3190:pci\ven_8086&dev_0116
Rank Of Driver: 00E02001
Video Accel: ModeMPEG2_A ModeMPEG2_C ModeVC1_C ModeWMV9_C
Deinterlace Caps: {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Ou...
0 项奖励
ssami3
初学者
5,052 次查看
hello nic please help me:
System Information
Time of this report: 5/22/2013, 23:03:00
Machine name: ME-PC
Operating System: Windows 7 Ultimate 32-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_rtm.101119-1850)
Language: Bengali (Regional Setting: Bengali)
System Manufacturer: Gigabyte Technology Co., Ltd.
System Model: G41M-ES2L
BIOS: Award Modular BIOS v6.00PG
Processor: Intel(R) Core(TM)2 Quad CPU Q8200 @ 2.33GHz (4 CPUs), ~2.3GHz
Memory: 4096MB RAM
Available OS Memory: 3036MB RAM
Page File: 1483MB used, 4587MB available
User DPI Setting: Using System DPI
System DPI Setting: 96 DPI (100 percent)
DxDiag Version: 6.01.7601.17514 32bit Unicode
DxDiag Notes
Sound Tab 2: No problems found.
Display Devices
Card name: Intel(R) G41 Express Chipset (Microsoft Corporation - WDDM 1.1)
Chip type: Intel(R) 4 Series Express Chipset Family
DAC type: Internal
Device Key: Enum\PCI\VEN_8086&DEV_2E32&SUBSYS_D0001458&REV_03
Display Memory: 1294 MB
Dedicated Memory: 32 MB
Shared Memory: 1262 MB
Current Mode: 1024 x 768 (32 bit) (60Hz)
Monitor Name: Generic Non-PnP Monitor
Monitor Model: unknown
Monitor Id:
Native Mode: unknown
Output Type: HD15
Driver Name: igdumd32.dll,igd10umd32.dll
Driver File Version: 8.15.0010.1749 (English)
Driver Version: 8.15.10.1749
DDI Version: 10
Driver Date/Size: 7/14/2009 07:15:31, 3805184 bytes
WHQL Logo'd: Yes
WHQL Date Stamp:
Device Identifier: {D7B78E66-6D72-11CF-3D71-0AF0A3C2C535}
Vendor ID: 0x8086
Device ID: 0x2E32
SubSys ID: 0xD0001458
Revision ID: 0x0003
Driver Strong Name: igdlh.inf:Intel.Mfg.NTx86...1:iEGL0:8.15.10.1749:pci\ven_8086&dev_2e32
Rank Of Driver: 00EC2001
Video Accel: ModeMPEG2_A ModeMPEG2_C ModeWMV9_B ModeWMV9_C ModeVC1_B ModeVC1_C
Deinterlace Caps: {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC3,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E3...
0 项奖励
NICHOLAS_F_Intel
5,052 次查看
0 项奖励
ssami3
初学者
5,052 次查看
Thanks a lot for your help
0 项奖励
CRome1
初学者
5,052 次查看
Hi nic, i
I have the same problem with my Dell Inspiron 1440. Sometimes it even shuts down showing a blue screen describing the error and then reboots. I tried going to the download center but none of those r for my CPU. PLEEEEASE HEEEEEEELP
System Information
Time of this report: 5/31/2013, 19:17:00
Machine name: FERNANDO2-PC
Operating System: Windows 7 Home Premium 32-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_gdr.130318-1533)
System Manufacturer: Dell Inc.
System Model: Inspiron 1440
BIOS: Phoenix ROM BIOS PLUS Version 1.10 A07
Processor: Intel(R) Core(TM)2 Duo CPU T6600 @ 2.20GHz (2 CPUs), ~2.2GHz
Memory: 4096MB RAM
Available OS Memory: 3546MB RAM
Page File: 1972MB used, 5118MB available
DxDiag Notes
Display Devices
Card name: Mobile Intel(R) 45 Express Chipset Family (Microsoft Corporation - WDDM 1.1)
Chip type: Mobile Intel(R) 4 Series Express Chipset Family
DAC type: Internal
Device Key: Enum\PCI\VEN_8086&DEV_2A42&SUBSYS_02CF1028&REV_07
Display Memory: 1549 MB
Shared Memory: 1517 MB
Current Mode: 1366 x 768 (32 bit) (60Hz)
Monitor Id: INL0002
Native Mode: 1366 x 768(p) (60.053Hz)
Output Type: Internal
DDI Version: 10
Driver Date/Size: 7/13/2009 20:15:31, 3805184 bytes
WHQL Logo'd: Yes
WHQL Date Stamp:
Device Identifier: {D7B78E66-6902-11CF-4D75-C522A7C2C535}
Vendor ID: 0x8086
Device ID: 0x2A42
SubSys ID: 0x02CF1028
Revision ID: 0x0007
Driver Strong Name: igdlh.inf:Intel.Mfg.NTx86...1:iCNT0:8.15.10.1749:pci\ven_8086&dev_2a42
{335AA36E-788...
0 项奖励
BBrot1
初学者
5,031 次查看
having the same issue over here
here is my dxdiag
System Information
Time of this report: 6/18/2013, 14:11:35
Machine name: SILVENTIS-PC
Operating System: Windows 7 Professional 64-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_gdr.130318-1533)
System Manufacturer: TOSHIBA
System Model: Satellite P505
BIOS: PhoenixBIOS 4.0 Release 6.1
Memory: 6144MB RAM
Available OS Memory: 5980MB RAM
Page File: 2236MB used, 9723MB available
DxDiag Notes
Display Devices
Card name: Mobile Intel(R) 4 Series Express Chipset Family
DAC type: Internal
Device Key: Enum\PCI\VEN_8086&DEV_2A42&SUBSYS_FF501179&REV_07
Display Memory: 1759 MB
Dedicated Memory: 128 MB
Shared Memory: 1631 MB
Current Mode: 1680 x 945 (32 bit) (60Hz)
Monitor Id: SEC324B
Native Mode: 1680 x 945(p) (60.000Hz)
Driver Name: igdumd64.dll,igd10umd64.dll,igdumdx32,igd10umd32
Driver File Version: 8.15.0010.2869 (English)
Driver Version: 8.15.10.2869
DDI Version: 10
Driver Date/Size: 11/14/2012 16:57:06, 6549504 bytes
WHQL Logo'd: Yes
WHQL Date Stamp:
Device Identifier: {D7B78E66-6902-11CF-FC79-5ADFA7C2C535}
Vendor ID: 0x8086
Device ID: 0x2A42
SubSys ID: 0xFF501179
Revision ID: 0x0007
Driver Strong Name: oem12.inf:IntelGfx.NTamd64.6.0:iCNT0:8.15.10.2869:pci\ven_8086&dev_2a42
Rank Of Driver: 00E62001
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC3,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoPro...
0 项奖励
RWile2
初学者
5,052 次查看
Hello Nic, I have had the same problem as these other people. Except it happens when i run a game. It loads the game all normal until it gets to main menu. Then it lags out putting me back to desktop bring up a Notice saying that my Graphics card has stopped running and has restored Please Help!!!!
System Information
Time of this report: 6/3/2013, 00:43:33
Machine name: DEVLIN-HP
System Manufacturer: Hewlett-Packard
System Model: p7-1050t
BIOS: Ver: CAR_714.ROM vCAR7.14
Processor: Intel(R) Pentium(R) CPU G620 @ 2.60GHz (2 CPUs), ~2.6GHz
Memory: 4096MB RAM
Available OS Memory: 4002MB RAM
Page File: 4408MB used, 3595MB available
DxDiag Notes
Display Devices
Card name: Intel(R) HD Graphics Family
DAC type: Internal
Device Key: Enum\PCI\VEN_8086&DEV_0102&SUBSYS_2AC2103C&REV_09
Display Memory: 1696 MB
Dedicated Memory: 64 MB
Shared Memory: 1632 MB
Current Mode: 1680 x 1050 (32 bit) (60Hz)
Monitor Model: DELL 2007WFP
Monitor Id: DELA019
Native Mode: 1680 x 1050(p) (59.883Hz)
Output Type: HDMI
Driver File Version: 8.15.0010.2291 (English)
Driver Version: 8.15.10.2291
DDI Version: 10.1
Driver Date/Size: 1/26/2011 20:57:14, 7470080 bytes
WHQL Logo'd: Yes
WHQL Date Stamp:
Device Identifier: {D7B78E66-4242-11CF-7F7B-C80AA9C2C535}
Vendor ID: 0x8086
Device ID: 0x0102
SubSys ID: 0x2AC2103C
Revision ID: 0x0009
Driver Strong Name: oem14.inf:Intel.Mfg.NTamd64:iSNBD0:8.15.10.2291:pci\ven_8086&dev_0102&subsys_2ac2103c
Rank Of Driver: 00E60001
Video Accel: ModeMPEG2_A ModeMPEG2_C ModeWMV9_C ModeVC1_C
0 项奖励
ASawa1
初学者
5,031 次查看
Hey there nic,i see you help many people with advices,i need your help too please,from 2-3 months ago i have this problem,Display driver Intel Graphics Accelerator Drivers for Windows Vista(R) stopped responding and has successfully recovered,Here you have my system details....
Thanks in Advance
System Information
Time of this report: 6/13/2013, 19:11:46
Machine name: ASHWINI
Operating System: Windows 7 Ultimate 32-bit (6.1, Build 7600) (7600.win7_rtm.090713-1255)
System Model: Compaq Presario CQ45 Notebook PC
BIOS: Default System BIOS
Processor: Intel(R) Pentium(R) Dual CPU T3200 @ 2.00GHz (2 CPUs), ~2.0GHz
Memory: 2048MB RAM
Available OS Memory: 2010MB RAM
Page File: 1289MB used, 2732MB available
DxDiag Version: 6.01.7600.16385 32bit Unicode
DxDiag Notes
Display Devices
DAC type: Internal
Device Key: Enum\PCI\VEN_8086&DEV_2A42&SUBSYS_30F7103C&REV_07
Display Memory: 781 MB
Shared Memory: 749 MB
Current Mode: 1280 x 800 (32 bit) (60Hz)
Monitor Id: LPL0132
Native Mode: 1280 x 800(p) (60.005Hz)
DDI Version: 10
Driver Date/Size: 7/14/2009 06:45:31, 3805184 bytes
WHQL Logo'd: Yes
WHQL Date Stamp:
Device Identifier: {D7B78E66-6902-11CF-5975-FD10A7C2C535}
Vendor ID: 0x8086
Device ID: 0x2A42
SubSys ID: 0x30F7103C
Revision ID: 0x0007
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_Str...
0 项奖励
NICHOLAS_F_Intel
5,031 次查看
@LadyThyme: you will want to download the .zip version of the file and use the "Have Disk" method. The link to the .zip for that driver is here;https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=22520&lang=eng Download Center
The guide for the have disk method is here; http://www.intel.com/support/graphics/sb/CS-033915.htm Graphics — How to update graphics driver for Microsoft Windows 7*
@Ashwini: Try this driver; https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=22165&lang=eng Download Center
0 项奖励
ASawa1
初学者
5,031 次查看
Hi nic,
I installed the driver. Now whenever I try to play any game, even Solitaire, I am getting error.
"The game is running in software rendering mode"
Hardware acceleration is either disabled or not supported by video card driver, which could slow game performance. Make sure you have the latest video card driver installed and that hardware acceleration is turned on.
Please Help.
Ashwini
0 项奖励
NICHOLAS_F_Intel
5,031 次查看
@Broten: I would recommend updating your BIOS and if that does not work, update your drivers using the ones provided by your OEM. What is the full model number of your laptop? Toshiba* Satellite P505-????
@Ashwini: Try doing a full uninstall of the graphics driver. You can find instructions for how to do that in the Readme.txt file that came with your graphics driver download. Afterwards, perform a re-install of the driver using the have-disk method outlined on this page; http://www.intel.com/support/graphics/sb/CS-033915.htm Graphics — How to update graphics driver for Microsoft Windows 7*
Let me know if after performing these two processes you are still experiencing the same issue or not.
-Nic
0 项奖励
BBrot1
初学者
5,031 次查看
Satellite P505-S8980
0 项奖励
NICHOLAS_F_Intel
5,031 次查看
@Broten: Try installing this BIOS update. I'm unsure which one you currently have installed (DxDiag is not displaying install date). http://support.toshiba.com/support/modelHome?freeText=2441113 Satellite P505-S8980 Support | Toshiba
0 项奖励
BBrot1
初学者
5,031 次查看
ACPI Flash BIOS version 3.10 for Satellite P500/P505 (PSPE0U/E8U, PSPG0U/G8U)
Would that be the right one?
0 项奖励
NICHOLAS_F_Intel
5,031 次查看
0 项奖励
BBrot1
初学者
5,031 次查看
Satellite P505-S8980 | Toshiba
Display driver Intel Graphics Accelerator Drivers for Windows XP (R) stopped responding then it successfully recovers and a few moments later completely crashes anything that i have up. I Use Windows 7 and I have tried updating my BIOS & Removed and installed the original Graphics card driver back onto the laptop & did everything else you have said earlier. It is doing the same thing it was doing before.
Resending my DxDiag:
System Information
Time of this report: 6/24/2013, 21:18:09
Memory: 6144MB RAM
Page File: 1869MB used, 10090MB available
DxDiag Notes
Display Devices
DAC type: Internal
Monitor Id: SEC324B
DDI Version: 10
WHQL Logo'd: Yes
WHQL Date Stamp:
Vendor ID: 0x8086
Device ID: 0x2A42
Revision ID: 0x0007
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC1,Y...
0 项奖励
NICHOLAS_F_Intel
5,031 次查看
@Broten: You may need to use the driver provided by your OEM. The drivers we provide are generic, and are not customized to work with your specific system. If your OEM has placed any customization on the functionality of the driver, you will need to try using theirs and see if the problem is resolved. A direct download link for the OEM driver for your system can be found here; http://cdgenp01.csd.toshiba.com/content/support/downloads/driver_video_intel_TC70056000B.exe http://cdgenp01.csd.toshiba.com/content/support/downloads/driver_video_intel_TC70056000B.exe
@SaaS: There are links within that document, one for each supported operating system. Choose which one matches the OS you are using, and follow the directions within. Let me know if you have any other questions.
Thank you,
-Nic
0 项奖励
回复
