22849 Discussions
Display Driver has stopped responding and has recovered
Hi. I know this question has been asked many times, but many are unanswered. I have a Dell Inspiron 1545, Window 7 64 bit. Just yesterday, my laptop kept blacking out, freezes and then unfreeze and this message would pop up saying, "Display driver stopped responding and has recovered. Display driver Intel Graphics Accelerator Drivers for Windows XP(R) stopped responding and has successfully recovered." It keeps happening around every 15-30 minutes. Sometimes, it totally blacks out. Other times, it unfreeze but the windows are blank. Someone please help me. The display adapter I have is Mobile Intel (R) 4 Series Express Chipset Family." Some people said online to update it and that might fix the problem. I went to the Intel website and updated the lastest one given, but the problem is still here. I've restored my laptop to a certain restore point, but still did not solve the problem. Suggestions and ideas? Thank you a head of time.
NICHOLAS_F_Intel
Hi Igor,
The driver for your system appears to be out of date. Additionally, there aren't any drivers listed for your system on your OEM's website! Go ahead and try our driver though; http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=21778&lang=eng http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=21778&lang=eng
Let me know how it goes.
-Nic
It said
Installed driver not tested for this computer.
Get the appropriate driver from the manufacturer.
The installation will be terminated.
Also i try to install this driver http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=22374&lang=eng Download Center but it said
This computer does not meet the minimum requirements for installing the software. Setup will exit.
It will not works on my computer?
NICHOLAS_F_Intel
The 2932 driver won't work for you because your generation of CPU is from the arrandale/clarkdale series (meaning 1st gen as opposed to 2nd/3rd which would work with that driver). The one I linked for you earlier is a 1st gen driver.
Did you try Right Click -> Run As Administrator for that driver? You may have to uninstall your current driver first as well.
-Nic
YEAH!!!
I have uninstall my current driver and now it works and there's no problems remain. Thank you very much man!!!
Hi!
I believe I am having a similar problem. After reading this thread I tried to install this driver http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=21776&keyword=152257.exe&DownloadType=Drivers&lang=eng Download Center , but got a message saying "This computer does not meet the minimum requirements for installing this software."
I have tried updating my drivers as well, but hasn't helped. Do you have any advice? Thanks.
Here is the full dxdiag report:
System Information
Time of this report: 1/13/2013, 23:53:58
Machine name: ANDREAM-PC
Operating System: Windows 7 Home Premium 64-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_gdr.120830-0333)
Language: English (Regional Setting: English)
System Manufacturer: ASUSTeK Computer Inc.
System Model: K50IJ
BIOS: Default System BIOS
Processor: Pentium(R) Dual-Core CPU T4500 @ 2.30GHz (2 CPUs), ~2.3GHz
Memory: 4096MB RAM
Available OS Memory: 4062MB RAM
Page File: 2796MB used, 5323MB available
Windows Dir: C:\Windows
DirectX Version: DirectX 11
DX Setup Parameters: Not found
User DPI Setting: Using System DPI
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
DxDiag Version: 6.01.7601.17514 32bit Unicode
DxDiag Notes
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Input Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (retail)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: Mobile Intel(R) 4 Series Express Chipset Family
Manufacturer: Intel Corporation
Chip type: Mobile Intel(R) 4 Series Express Chipset Family
DAC type: Internal
Device Key: Enum\PCI\VEN_8086&DEV_2A42&SUBSYS_18621043&REV_09
Display Memory: 1695 MB
Dedicated Memory: 32 MB
Shared Memory: 1663 MB
Current Mode: 1366 x 768 (32 bit) (60Hz)
Monitor Name: Generic PnP Monitor
Monitor Model: unknown
Monitor Id: LGD01E8
Native Mode: 1366 x 768(p) (59.973Hz)
Output Type: Internal
Driver Name: igdumd64.dll,igd10umd64.dll,igdumdx32,igd10umd32
Driver File Version: 8.15.0010.1892 (English)
Driver Version: 8.15.10.1892
DDI Version: 10
Driver Model: WDDM 1.1
Driver Attributes: Final Retail
Driver Date/Size: 1/9/2013 01:27:17, 5617664 bytes
WHQL Logo'd: Yes
WHQL Date Stamp:
Device Identifier: {D7B78E66-6902-11CF-9774-6838A9C2C535}
Vendor ID: 0x8086
Device ID: 0x2A42
SubSys ID: 0x18621043
Revision ID: 0x0009
Driver Strong Name: oem23.inf:Intel.Mfg.NTamd64:iCNT0:8.15.10.1892:pci\ven_8086&dev_2a42
Rank Of Driver: 00E62001
Video Accel: ModeMPEG2_A ModeMPEG2_C ModeWMV9_B ModeWMV9_C ModeVC1_B ModeVC1_C
Deinterlace Caps: {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC2,YUY2) Frames(Prev/Fwd/Back)=(0...
NICHOLAS_F_Intel
Hi Andy,
You're running Windows* 7 64-bit, and the driver you were attempting to install was for Vista*. Here's a download link to our latest driver for your system; http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=22166&lang=eng http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=22166&lang=eng
Let me know if it works.
-Nic
Nic,
I installed the drivers, but am still having the same problem. Any other advice? Thanks.
MEA1
New Contributor II
You have to uninstall your current driver before installing the new one.
NICHOLAS_F_Intel
@_andym_: Okay if our driver isn't working for you, I would recommend trying the one provided by your OEM* Here's a link to the download page for your product; http://support.asus.com/download.aspx?SLanguage=en&p=3&m=K50IJ&hashedid=ZWrNVPXEbNNTjJZg http://support.asus.com/download.aspx?SLanguage=en&p=3&m=K50IJ&hashedid=ZWrNVPXEbNNTjJZg
Choose the option listed under "VGA" with the version # : 8.15.10.2021. Let me know if this works for you.
@Kwesi: You are having the driver not responding error as well? Can you provide for me a copy of your dxdiag? (Start -> Run -> dxdiag -> Save All Information) Copy and paste it here so I can look at it.
-Nic
I still seem to be having issues.
Is there any way to tell if it is a hardware issue rather than a software issue? (I don't think it is, but I'd like to know for sure). Thanks.
Hi nic!
It seems I have a same problem - "Intel Media Accelerator stopped responding and has been successfully recovered". Now it appears in every 10 to 15 minutes while surfing the internet (pictures, videos, games on FB etc.)
So I'm hoping you can help me, please. Thanks!
Here is my dxdiag:
System Information
Time of this report: 1/17/2013, 15:44:35
Machine name: KNJIZNICA
Operating System: Windows 7 Enterprise 32-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_gdr.120830-0333)
Language: Croatian (Regional Setting: Croatian)
System Manufacturer: Hewlett-Packard
System Model: HP 500B Microtower
BIOS: BIOS Date: 08/12/10 11:36:37 Ver: 6.05
Processor: Intel(R) Celeron(R) CPU E3400 @ 2.60GHz (2 CPUs), ~2.6GHz
Memory: 2048MB RAM
Available OS Memory: 2014MB RAM
Page File: 1579MB used, 2446MB available
DxDiag Notes
Display Devices
Card name: Intel(R) G41 Express Chipset (Microsoft Corporation - WDDM 1.1)
Chip type: Intel(R) 4 Series Express Chipset Family
DAC type: Internal
Device Key: Enum\PCI\VEN_8086&DEV_2E32&SUBSYS_2A8C103C&REV_03
Display Memory: 782 MB
Shared Memory: 750 MB
Monitor Model: HP LE1851w
Monitor Id: HWP2840
Native Mode: 1366 x 768(p) (59.790Hz)
Output Type: HD15
Driver Name: igdumd32.dll,igd10umd32.dll
Driver File Version: 8.15.0010.1749 (English)
Driver Version: 8.15.10.1749
DDI Version: 10
Driver Date/Size: 7/14/2009 02:15:31, 3805184 bytes
WHQL Logo'd: Yes
WHQL Date Stamp:
Device Identifier: {D7B78E66-6D72-11CF-5975-860AA3C2C535}
Vendor ID: 0x8086
Device ID: 0x2E32
SubSys ID: 0x2A8C103C
Revision ID: 0x0003
Driver Strong Name: igdlh.inf:Intel.Mfg.NTx86...1:iEGL0:8.15.10.1749:pci\ven_8086&dev_2e32
Rank Of Driver: 00EC2001
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: For...
NICHOLAS_F_Intel
Hi dorothy,
Go ahead and try installing our latest driver for your system (Dell* doesn't appear to have one listed in their driver page for you); http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=22163&lang=eng http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=22163&lang=eng
Let me know if this fixes your issue or not.
-Nic
Nic,
I installed the driver provided by my OEM (VGA version # : 8.15.10.2021). However, it has not solved the problem with my display driver. Do you have any other suggestions? Should I try installing the latest driver intel has for my system again? Thanks.
Hi Nic,
I installed the new driver and apparently the problem is solved. I hope it won't start again after a while.
Thanks a lot!!!
Hi Nic,
this is my problem.... what to do i'm clueless?
System Information
Time of this report: 1/19/2013, 00:09:51
Machine name: ADEL-PC
Operating System: Windows 7 Ultimate 64-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_gdr.120830-0333)
Language: Hebrew (Regional Setting: Hebrew)
System Manufacturer: Dell Inc.
System Model: Inspiron 1545
BIOS: Phoenix ROM BIOS PLUS Version 1.10 A10
Processor: Pentium(R) Dual-Core CPU T4200 @ 2.00GHz (2 CPUs), ~2.0GHz
Memory: 2048MB RAM
Available OS Memory: 2008MB RAM
Page File: 2021MB used, 1995MB available
DxDiag Notes
Display Devices
Card name: Mobile Intel(R) 45 Express Chipset Family (Microsoft Corporation - WDDM 1.1)
DAC type: Internal
Device Key: Enum\PCI\VEN_8086&DEV_2A42&SUBSYS_02AA1028&REV_07
Display Memory: 780 MB
Shared Memory: 748 MB
Current Mode: 1366 x 768 (32 bit) (59Hz)
Monitor Id: INL0001
Native Mode: 1366 x 768(p) (59.967Hz)
DDI Version: 10
Driver Date/Size: 7/14/2009 03:41:07, 5437952 bytes
WHQL Logo'd: Yes
WHQL Date Stamp:
Device Identifier: {D7B78E66-6902-11CF-4D75-A022A7C2C535}
Vendor ID: 0x8086
Device ID: 0x2A42
SubSys ID: 0x02AA1028
Revision ID: 0x0007
Driver Strong Name: igdlh.inf:Intel.Mfg.NTamd64...1:iCNT0:8.15.10.1749:pci\ven_8086&dev_2a42
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC3,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC3,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps...
NICHOLAS_F_Intel
Hi eilamnir. Thanks for providing that info up front Go ahead and try our latest driver for your chipset; http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=22167&lang=eng http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=22167&lang=eng
I checked Dell's* site and the latest driver they had for you was significantly outdated.. let me know if this one resolves your issue.
-Nic
Hi there, i have also this problem. nic can u help me . i m desperately need help. i think after i install new catalyst software, my games run slower and also this error bumped all the time.. here is diax
System Information
Time of this report: 1/31/2013, 19:51:55
Machine name: POCO
Language: Turkish (Regional Setting: Turkish)
System Manufacturer: Gigabyte Technology Co., Ltd.
System Model: P35-DS3L
BIOS: Award Modular BIOS v6.00PG
Processor: Intel(R) Core(TM)2 Duo CPU E8400 @ 3.00GHz (2 CPUs), ~3.0GHz
Memory: 6144MB RAM
Available OS Memory: 6142MB RAM
Page File: 2474MB used, 9808MB available
DxDiag Version: 6.01.7601.17514 64bit Unicode
DxDiag Notes
Sound Tab 2: No problems found.
Display Devices
Card name: AMD Radeon HD 5500 Series
Manufacturer: Advanced Micro Devices, Inc.
Chip type: AMD Radeon Graphics Processor (0x675F)
DAC type: Internal DAC(400MHz)
Device Key: Enum\PCI\VEN_1002&DEV_675F&SUBSYS_E193174B&REV_00
Display Memory: 3827 MB
Dedicated Memory: 1012 MB
Shared Memory: 2815 MB
Current Mode: 1680 x 1050 (32 bit) (60Hz)
Monitor Name: SyncMaster 226CW,SyncMaster Magic CX226CW(Digital)
Monitor Model: SyncMaster
Monitor Id: SAM030F
Native Mode: 1680 x 1050(p) (59.883Hz)
Output Type: DVI
Driver Name: aticfx64.dll,aticfx64.dll,aticfx64.dll,aticfx32,aticfx32,aticfx32,atiumd64,atidxx64.dll,atidxx64.dll,atiumdag,atidxx32,atidxx32,atiumdva,atiumd6a.cap,atitmm64.dll
Driver File Version: 8.17.0010.1172 (English)
Driver Version: 9.12.0.0
DDI Version: 11
Driver Date/Size: 12/19/2012 22:08:04, 1151488 bytes
WHQL Logo'd: Yes
WHQL Date Stamp:
Device Identifier: {D7B71EE2-241F-11CF-6F70-99C1BEC2C535}
Vendor ID: 0x1002
Device ID: 0x675F
SubSys ID: 0xE193174B
Revision ID: 0x0000
Driver Strong Name: oem42.inf:ATI.Mfg.NTamd64.6.1:ati2mtag_NI:9.12.0.0:pci\ven_1002&dev_675f
Video Accel:
Deinterlace Caps: n/a
D3D9 Overlay: n/a
DXVA-HD: n/a
DDraw Status: Not Available
D3D Status: Enabled
AGP Status: Not Available
Sound Devices
Description: Speakers (Realtek High Definition Audio)
Default Sound Playback: Yes
Default Voice Playback: Yes
Hardware ID: HDAUDIO\FUNC_01&VEN_10EC&DEV_0888&SUBSYS_1458E601&REV_1000
Manufacturer ID: 1
Product ID: 100
Type: WDM
Driver Name: RTKVHD64.sys
Driver Version: 6.00.0001.5973 (English)
WHQL Logo'd: Yes
Date and Size: 11/3/2009 13:39:58, 2023840 bytes
Other Files:
Driver Provider: Realtek Semiconductor Corp.
HW Accel Level: Basic
Cap Flags: 0xF1F
Min/Max Sample Rate: 100, 200000
Static/Strm HW Mix Bufs: 1, 0
Static/Strm HW 3D Bufs: 0, 0
HW Memory: 0
Voice Management: No
EAX(tm) 2.0 Listen/Src: No, No
I3DL2(tm) Listen/Src: No, No
Sensaura(tm) ZoomFX(tm): No
Description: Realtek Digital Output (Realtek High Definition Audio)
Default Sound Playback: No
Default Voice Playback: No
Manufacturer ID: 1
Product ID: 100
Type: WDM
WHQL Logo'd: Yes
Other Files:
Cap Flags: 0xF1F
HW Memory: 0
Sound Capture Devices
Description: Microphone (VF0420 Live! Cam Vista IM)
Default Sound Capture: Yes
Default Voice Capture: Yes
Driver Name: USBAUDIO.sys
Driver Version: 6.01.7601.17514 (English)
Date and Size: 11/20/2010 12:43:52, 109696 bytes
Cap Flags: 0x1
Format Flags: 0xFFFFF
Description: Realtek Digital Input (Realtek High Definition Audio)
Default Sound Capture: No
Default Voice Capture: No
Cap Flags: 0x1
DirectInput Devices
Device Name: Mouse
Attached: 1
Contr...
NICHOLAS_F_Intel
Hi Orcun! Since your display issue seems to be with your AMD* card, I would recommend you contact them for assistance on this issue.
-Nic
Been a while since I been on here. I said I was giving up because nothing was helping. I just wanted to say that it seems worse when I'm on Firefox. I hate using Explorer, but it doesn't cause it to freeze so much. On Firefox I scroll down not even a half an inch and it freezes. It takes a long time to get to the end of the page if it doesn't freeze up completely and I have to unplug it and take the battery out. I also have to run in safe mode with networking if I need to be on for a while and don't want the problems.
NICHOLAS_F_Intel
Hi Ikyuri. Go ahead and try our latest driver for your system, let me know if it resolves the issue; http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=22167&lang=eng http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=22167&lang=eng
@Sabrina; Try using the same driver I just provided for Ikyuri. Before when we were troubleshooting we never verified (correct me if I'm wrong on this) that the issues still persist even with our latest. Let me know how it goes.
-Nic
