23734 Discussions
Display output 10 bit not working
ManojKumarM
I'm having HP-Pavilion-au-117tx laptop.
When transferring the display output to TV through HDMI the color depth is only 8-bit and not 10-bit.
Could anyone help me to acheive the solution to this issue?
Thanks in advance 🙂
ManojKumarM
My Graphics driver is Intel HD Graphics 620 and Nvidia Geforce 940MX.
And i7-7500U CPU.
n_scott_pearson
AFAIK, 10-Bit mode is only used for HDR support.
ManojKumarM
But When I am connecting another laptop to the same TV the bit depth shows 10-bit and  the color space is Standard Dynamic Range (SDR).
(That laptop is having AMD Radeon(TM) Vega 10 Graphics)
n_scott_pearson
Yea, so? This is Intel graphics are implemented; that is how AMD graphics is implemented; simply not the same animals.
David_G_Intel
Hello @ManojKumarM
Thank you for posting on the Intel️® communities.
Please provide the following reports to assist you:
  • Intel® System Support Utility (Intel® SSU)
    • Download the Intel SSU https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows
    • Open the application and select "Everything" click on "Scan" to see the system and device information. By default, Intel® SSU will take you to the "Summary View".
    • Click on the menu where it says "Summary" to change to "Detailed View".
    • To save your scan, click on "Next", then "Save".
  •  Intel® Graphics Command Center report
    • "Support" > "System Diagnostic" > "Generate Report
David G
Intel Customer Support Technician
David_G_Intel
David G.
David_G_Intel
David G.
