22889 Discussions
Does my Intel 520 on my Surface Book support 3 monitors via a Startech MSTMDP123DP Hub?
JRadk
Hello Intel Community,
Would appreciate it if you could answer the following question :
I have a Surface Book from Microsoft (not the Performance Base model, but the previous one) . Information from my system in the notes below . The question is : can I use 3 monitors (1-built in, 2 - external, 3- external ) , provided i am using a Startech MSTMDP123DP 3-Port multi monitor min displayport to Display Port MST Hub ?
At the moment I have all three connected, but my system doesnt pick-up the 3rd monitor.
1st Monitor is the Surface Book built-in display.
2nd Monitor is my external Display (connected via HDMI cable)
3rd Monitor is my 2nd external Display ( connected via HDMI cable to DVI adapter, because the Monitor only has DVI port , hence cannot use HDMI with it ) .
For more details i am including the output of my dxdiag.
System Information
   Time of this report: 2/19/2019, 10:29:54
       Machine name:
        Machine Id: {}
     Operating System: Windows 10 Enterprise 64-bit (10.0, Build 17763) (17763.rs5_release.180914-1434)
         Language: English (Regional Setting: English)
   System Manufacturer: Microsoft Corporation
       System Model: Surface Book
           BIOS: 91.2439.769 (type: UEFI)
        Processor: Intel(R) Core(TM) i7-6600U CPU @ 2.60GHz (4 CPUs), ~2.8GHz
          Memory: 8192MB RAM
   Available OS Memory: 8118MB RAM
        Page File: 10397MB used, 3608MB available
       Windows Dir: C:\WINDOWS
     DirectX Version: DirectX 12
   DX Setup Parameters: Not found
     User DPI Setting: 96 DPI (100 percent)
    System DPI Setting: 192 DPI (200 percent)
     DWM DPI Scaling: Disabled
         Miracast: Available, with HDCP
Microsoft Graphics Hybrid: Supported
      DxDiag Version: 10.00.17763.0001 64bit Unicode
Display Devices
      Card name: Intel(R) HD Graphics 520
    Manufacturer: Intel Corporation
      Chip type: Intel(R) HD Graphics Family
      DAC type: Internal
     Device Type: Full Device (POST)
     Device Key: Enum\PCI\VEN_8086&DEV_1916&SUBSYS_00141414&REV_07
    Device Status: 0180200A [DN_DRIVER_LOADED|DN_STARTED|DN_DISABLEABLE|DN_NT_ENUMERATOR|DN_NT_DRIVER]
 Device Problem Code: No Problem
 Driver Problem Code: Unknown
   Display Memory: 4186 MB
  Dedicated Memory: 128 MB
    Shared Memory: 4058 MB
    Current Mode: 1920 x 1200 (32 bit) (60Hz)
     HDR Support: Not Supported
  Display Topology: Extend
 Display Color Space: DXGI_COLOR_SPACE_RGB_FULL_G22_NONE_P709
   Color Primaries: Red(0.639648,0.330078), Green(0.299805,0.599609), Blue(0.150391,0.059570), White Point(0.312500,0.329102)
  Display Luminance: Min Luminance = 0.500000, Max Luminance = 270.000000, MaxFullFrameLuminance = 270.000000
    Monitor Name: Surface Display
    Monitor Model: VVX14P048M00
     Monitor Id: MEI96A2
     Native Mode: 3000 x 2000(p) (59.985Hz)
     Output Type: Internal
Monitor Capabilities: HDR Not Supported
Display Pixel Format: DISPLAYCONFIG_PIXELFORMAT_32BPP
   Advanced Color: Not Supported
     Driver Name: C:\WINDOWS\System32\DriverStore\FileRepository\64gh6293.inf_amd64_22fd8f9659edd17f\igdumdim64.dll,C:\WINDOWS\System32\DriverStore\FileRepository\64gh6293.inf_amd64_22fd8f9659edd17f\igd10iumd64.dll,C:\WINDOWS\System32\DriverStore\FileRepository\64gh6293.inf_amd64_22fd8f9659edd17f\igd10iumd64.dll,C:\WINDOWS\System32\DriverStore\FileRepository\64gh6293.inf_amd64_22fd8f9659edd17f\igd12umd64.dll
 Driver File Version: 24.20.0100.6293 (English)
   Driver Version: 24.20.100.6293
     DDI Version: 12
   Feature Levels: 12_1,12_0,11_1,11_0,10_1,10_0,9_3,9_2,9_1
    Driver Model: WDDM 2.1
 Graphics Preemption: Triangle
 Compute Preemption: Thread
      Miracast: Supported
 Hybrid Graphics GPU: Integrated
   Power P-states: Not Supported
   Virtualization: Not Supported
     Block List: No Blocks
 Catalog Attributes: Universal:False Declarative:False
  Driver Attributes: Final Retail
  Driver Date/Size: 9/26/2018 1:00:00 AM, 2018392 bytes
     WHQL Logo'd: Yes
   WHQL Date Stamp: Unknown
  Device Identifier: {D7B78E66-5A56-11CF-316F-7020BCC2D535}
      Vendor ID: 0x8086
      Device ID: 0x1916
      SubSys ID: 0x00141414
     Revision ID: 0x0007
 Driver Strong Name: oem81.inf:5f63e534f36b7c6d:iSKLD_w10_DS:24.20.100.6293:pci\ven_8086&dev_1916&subsys_00141414
   Rank Of Driver: 00D10001
     Video Accel: ModeMPEG2_A ModeMPEG2_C ModeWMV9_C ModeVC1_C
     DXVA2 Modes: DXVA2_ModeMPEG2_VLD DXVA2_ModeMPEG2_IDCT DXVA2_ModeVC1_D2010 DXVA2_ModeWMV9_IDCT DXVA2_ModeVC1_IDCT DXVA2_ModeH264_VLD_NoFGT DXVA2_ModeH264_VLD_Stereo_Progressive_NoFGT DXVA2_ModeH264_VLD_Stereo_NoFGT DXVA2_ModeH264_VLD_Multiview_NoFGT DXVA2_ModeHEVC_VLD_Main DXVA2_ModeHEVC_VLD_Main10
Wanner_G_Intel
Hello JRadk, By using Multi-Stream Transport (MST) capabilities, you should be able to distribute one DisplayPort* signal across multiple monitors (DisplayPort* or HDMI* monitors). However, video resolutions will be limited. Since Intel® HD Graphics supports DisplayPort* 1.2, you can configure three displays (built-in monitor + 2 external monitors). If you have any further questions, please let us know. Wanner G. Intel Customer Support Technician Under Contract to Intel Corporation
JRadk
Thank you for the confirmation. This takes care of one little piggy. If the card indeed supports this, then i will proceed with additional troubleshooting via:
1) resolution
2) dongles ( as suggested by n.scott.pearson below ) and BIOS
n_scott_pearson
Let me make sure I understand correctly: You are connecting this MST Hub to the laptop. You then have a DP-to-HDMI adapter between the MST Hub and the first monitor and a DP-to-HDMI adapter plus a HDMI-to-DVI adapter between the MST Hub and the second monitor.
In theory, this should have worked. I do, however, see a couple of possibilities for why it is failing:
  • The presence of the paired dongles on the second monitor is causing the monitor to not be detected. Check for this using another HDMI monitor (surely you have a TV that could be temporarily repurposed for this test).
  • The BIOS is not simply prepared to handle the MST Hub being there and is thus nor checking for a second monitor. If this is the case, you are simply out of luck.
Hope this helps,
JRadk
Thanks for the advice. I will try to add the TV temporarily to see if it will be detected and update the thread.
JRadk
Again, thanks for the advice, but unfortunately i am not progressing.
Here is what i did :
Instead of the 2nd external monitor ( which was connected via HDMI and then DVI adapter to the monitor's DVI port ) I connected my TV. My TV has HDMI , so I no longer needed the DVI adapter.
In essence the setup became:
1)Laptop built-in display
2)MST Hub connected to laptop mini displayport
3) 1st external monitor ,connected via MST Hub HDMI to Monitor's HDMI
4) 2nd external monitor - TV, connected via MST Hub HDMI to TV's HDMI
Pressing the MST Hub's rescan button doesnt detect the TV in 4) and Windows doesnt see additional screens.
The laptop's display and the 1st external monitor work just fine.
I then tried plugging in the cables in the MST hub in a different order , but that also doesnt work. The TV ( under 4) is still not detected.
I then set things up the following way and my surface book still didnt recognize the TV:
3) 2nd external monitor - TV, connected via MST Hub HDMI to TV's HDMI
So the question remains : Does the surface book graphics card i have (listed above) support the laptop built in display and 2 additional external monitors ?
Thanks Intel
P.S. I also tried disabling my Nvidia Card dGPU from the BIOS to see if this will bring any changes. No.
Wanner_G_Intel
Hello JRadk, Were you able to test the steps provided on this thread? Wanner G. Intel Customer Support Technician Under Contract to Intel Corporation
Wanner_G_Intel
Hello JRadk, Thank you for your response. Your processor graphics supports three displays (built-in monitor + 2 external monitors). However, Original Equipment Manufacturers (OEMs) usually modify how many displays you can connect at the same time. This also depends on the video connections your system supports. In this scenario, we recommend following these recommendations: 1. Use another adapter. 2. Change the supported resolutions and refresh rates for your device. 3. Make sure the monitors are using the latest firmware or driver versions. 4. If available, check the list of supported monitor configuration and monitors supported by your system. 5. If your product uses a Surface Dock, your OEM may also have a list of validated peripherals. 6. Make sure you are running the latest updates for Windows* and OEM drivers. Wanner G. Intel Customer Support Technician Under Contract to Intel Corporation
n_scott_pearson
And if you have problems, call Microsoft. The Surface Book is *their* design with *their* BIOS. There are all sorts of things that they could do that would block the monitor configuration.
