Após a última atualização do windows 10 home x64 (versão 1809 - data da atualização 12/março/2019) ao atualizar o driver de vídeo, o sistema congela. Possuo um i7-4790k. O driver baixado é da data de 19/março/2019 - Versão: 15.40.42.5063.
Fiz e refiz testes, ao utilizar o sistema operacional sem o driver, funciona, porém ao atualizar o driver Gráficos HD Intel® 4600 o sistema congela de imediato.
Don't attempt to update. Uninstall the previous solution completely (which may take multiple uninstall operations; do it until you see the Microsoft driver associated with the solution) and then install the latest (which is indeed 5063).
Hope this helps,
This is what I did, after presenting this problem of freezing, I downloaded the drive from March 19, 2019 - Version: 15.40.42.5063 in my notebook and I went through a pendrive to my desktop PC and did the installation in which it generated the same problem.
The installation of windows 10 home x64 was the last available (I believe it is dated 08 / January / 2019), where it worked without any problem, only accused the video driver was outdated.
It was where I did the previous process, I transferred the installer of the drive to the pendrive, and during the installation (when the screen flashes and updates the drive) the system freezes.
I am not sure what to suggest. The driver installed just fine on my i7-4770K system.
Yeah, but I dont know what to do... Maybe works for you because family of processor, your is Haswell and mine is Devil's Canyon.
But thanks for try to help me!
Hii, thanks for try to help me.
The attach was the scan result.
After step 13, for a second, I had hope, but the system froze again.
And I opened a "ticket" on Gigabyte too.
Hi Leo, after contact support from gigabyte, they told me to update chipset and update bios, after this, the SO stopped freezes. The windows 10 is compatible with the motherboard, by the way.
![](/skins/images/7B0AB6865064EAE32B30EC9A4E94B48A/responsive_peak/images/icon_anonymous_message.png)
