22660 Diskussionen
Final Fantasy XV crashing!
sstee1
Einsteiger
5.635Aufrufe
Into the game for about 5-10 minutes and it crashes with direct x error (device hung) .Picture attached.Please Help
10 Antworten
AlHill
Superuser
4.199Aufrufe
Not a lot of information to go on.
Provide:
your complete processor model number
your system/motherboard model number
your operating system. if windows 10, provide the complete release build of what you are running.
your graphics
Doc
sstee1
Einsteiger
4.199Aufrufe
Al_Hill Thanks for the reply sir.I have 8gb ram ddr4 2400mhz and Intel hd 620 .Other details are attached
Mitarbeiter
4.199Aufrufe
Thank you very much for your help Al Hill.
raulmenendez: Thank you very much for contacting the Intel® Communities Team.
I would like to know if you have contactedhttp://www.dell.com/support/home/cr/en/crbsdt1 DELL* to run some test just to make sure this is not a hardware issue. Furthermore, have you tried installing the http://www.dell.com/support/home/cr/en/crbsdt1/product-support/product/vostro-14-3468-laptop/drivers graphics drivers provided by them? I would like to know as well if you have checked with the http://support.eu.square-enix.com/main.php?id=612&la=2 developers Final Fantasy* XV if your laptop is having the minimum requirements to run the game or the recommended configuration. Additionally, can you please provide me with the .txt file that the https://downloadcenter.intel.com/downloads/eula/25293/Intel-System-Support-Utility-for-Windows-?httpDown=https://downloadmirror.intel.com/25293/eng/SSU.exe System Support Utility will generate. To attach a file, you must click the "Attach" option on the bottom right-hand corner of the response box.
Antony S.
sstee1
Einsteiger
4.199Aufrufe
Sir i have not contacted dell as i am pretty sure there cannot be a hardware issue as every other game is running fine and system is running as it should.I have the latest drivers installed.This game runs well on low preset with smooth framerate. There come a sudden crash error randomly while playing everytime after 10 or 15 minutes,picture of which i have already posted above in this thread. I have attached system utility file you asked.Waiting for the response and fix
sstee1
Einsteiger
4.199Aufrufe
intel_corp Any fix yet!.Or guess i should wait for the new drivers?
MWins2
Einsteiger
4.199Aufrufe
i'm a gamer myself, in my opinion its all working fine but that is the most performance you can get from that hardware. there's nothing wrong with anything everything is working fine but just because that hardware cannot produce more memory required by the game. waiting for new drivers is pointless, if you can, enjoy this game on low graphics with perfect frame rate or you need to upgrade your specs to get more out of it.
McNeil Winston
sstee1
Einsteiger
4.199Aufrufe
McneillWinston a couple of months back wolfenstein 2 was having same crash errors and wasn't even launching.Newer drivers made that game run and work.
p.s:I am on the laptop can't upgrade much!
MWins2
Einsteiger
4.199Aufrufe
ohh lets hope for the best then, i know you're on laptop yea that sucks that we're always restricted on laptops, bounded to same hardware
i am with Inspiron 7567 with 1050ti and its wonderful on high graphics. trust me highest graphic settings is the way to enjoy games.
Mitarbeiter
4.199Aufrufe
Thank you very much for your reply and the information provided, raulmenendez.
I would like to know which resolution and refresh rate you are using while playing. Furthermore, are you using an external monitor? If so, please let me know which type of cable are you using. And, for testing purposes, please try installing these https://downloadmirror.intel.com/27058/eng/win64_154605.4771.zip drivers. Please use this guide to install them: https://www.intel.com/content/www/us/en/support/articles/000005629/graphics-drivers.html https://www.intel.com/content/www/us/en/support/articles/000005629/graphics-drivers.html
Antony S.
sstee1
Einsteiger
4.199Aufrufe
intel_corp Drivers actually worked!!Thanks alot!!No more error.I am playing on 1024*768 and low preset and screen refresh rate is 60 Hz.No external monitor. Its running fine for me now.Thumbs up!
Antworten
