22660 Discusiones
Fortnite stuttering frequently on latest driver
JLa1
Novato
8.074 Vistas
Category
Questions
Answers (N/A if not applicable)
Description
Provide a detailed description of the issue
Fortnite stutters frequently in game especially while in high combat situations. (Ex. 50v50 when everyone is in the small circle battling it out) This issue seems to happen randomly (however occurs way more frequently in combat as mentioned above). In some severe cases, the game can freeze for several seconds.
Interestingly, the issue does NOT occur in a very very old version of the driver from 2016. This version is 21.20.16.4494. This was obtained from Acer's website and is labeled "VGA Driver (Kabylake)" on their website https://www.acer.com/ac/en/CA/content/support-product/6752?b=1&pn=NX.GE6AA.015 here. On this driver, the game only stutters after loading into a match and/or after jumping from the battle bus. Not during combat or gameplay after landing.
Please place an X to the right of the option showing how often you see this issue using specific steps. (Ex: 'Every few times a game is started it flickers.' <- This would be "Often")<p>
Always (100%):
Often (51-99%):
Sporadic (20-50%): X
Very Sporadic (<20%):
Hardware (HW)
Brand and Model of the system.
Acer Aspire E5-575-5476
Hybrid or switchable graphics system?
ie Does it have AMD or NV...
0 kudos
11 Respuestas
Empleados
5.284 Vistas
Hello Jacky161
Thank you for joining the community.
Could you provide me with an example of the issue, if it is possible please provide me with an FPS counter while ruing the fame?
Leonardo C.
JLa1
Novato
5.284 Vistas
I've attached a few graphs to show the FPS decrease during stuttering using MSI Afterburner. I also attached a graph of using the older driver which did not stutter.
The frametime is the bottom number and FPS is the top number.
Here is a graph of the old driver during gameplay.
I have also attached the .HML file which you can open in MSI Afterburner to view the graphs in detail. You may notice large FPS boosts and dips at the beginning and end of the graphs, that's just during the loading screen and not during gameplay. Also, sidenote it appears GPU Usage % counting is broken using the latest driver as well.
Empleados
5.284 Vistas
Hello Jacky161
Thank you for your response and for all the information provided about the case; allow me to investigate more this behavior for you, I will be posting back as soon as news becomes available.
Leonardo C.
JLa1
Novato
5.284 Vistas
Any updates? I just tried the driver released yesterday (24.20.100.6229) and it hasn't gotten any better.
Empleados
5.284 Vistas
Hello Jacky161
Thank you for you the update, I am working on testing this behavior with the Intel® HD graphics 620, I will be posting back as soon as I have updates.
Leonardo C.
Empleados
5.284 Vistas
Hello Jacky161
Thank for waiting, we are working in the configuration that you are running, please share with us the game settings that you are running if possible with pictures.
Have you tested the Intel® HD graphics 620 driver version 24.20.100.6286? (https://downloadmirror.intel.com/27988/a08/win64_24.20.100.6286.zip https://downloadmirror.intel.com/27988/a08/win64_24.20.100.6286.zip) see steps to install driver below.
Have you tried to use the setting on https://gameplay.intel.com/ https://gameplay.intel.com/ for your Intel® processor/HD graphics? (https://gameplay.intel.com/en-us/CPUAndGameSelected/Index/95443/641893 https://gameplay.intel.com/en-us/CPUAndGameSelected/Index/95443/641893)
First, you will have download the Intel® HD graphics 630 driver version on the following link https://downloadmirror.intel.com/27988/a08/win64_24.20.100.6286.zip https://downloadmirror.intel.com/27988/a08/win64_24.20.100.6286.zip, once the driver is downloaded please make sure that the unit is not connected to the internet during the uninstall/install driver to avoid any automatic update, and follow these steps to uninstall the graphics drivers:
  1. On the keyboard, press WinLogo key + R, then type in devmgmt.msc
  2. Expand the Display Adapters section.
  3. Find the Intel® Graphics Driver. The driver can also be called the Intel® Graphics Media Accelerator Driver (Intel® GMA Driver).
  4. Right-click the Intel Graphics Driver and select Uninstall.
  5. Select the checkbox Delete the driver software for this device.
  6. Reboot the computer after the uninstall process has finished.
Once the reboot is completed, please follow these steps in order to update the graphics driver:
  1. Use the .zip file downloaded previously.
  2. Unzip the file to a designated location or folder.
  3. Right-click on the Windows Start icon and open Device Manager.
  4. Click "Yes" when prompted for permission from User Account Control.
  5. Expand the Display adapters section.
  6. Right-click the Intel® graphics entry and select Update Driver Software.
  7. Click "Browse my computer for driver software".
  8. Click "Let me pick from a list of device drivers on my computer".
  9. Click "Have Disk".
  10. Click "Browse".
  11. Access the designated location or folder, and access a folder called "Graphics".
  12. Select the file called "igdlh64" or "igdlh".
  13. Click Open, then click OK, and finally click "Next". Drivers are now being installed.
  14. Reboot your computer.
Hope this help.
Leonardo C.
JLa1
Novato
5.284 Vistas
I just tried the new driver and it seems to be a bit better but still not great. Jumping out of the battle bus is horrible with lots of stuttering still and combat is not much better. General gameplay seems to be a bit better though but not perfect. Using the settings from the website seems to make jumping out of the battle bus quite a bit better. Gameplay feels about the same as my previous settings and combat would probably be the same as well even though I didn't test that. I have attached the settings I used below.
Empleados
5.284 Vistas
Hello Jacky161
Thank you for the information.
Thank you for the update on the problem and the testing, allow me to set the configuration on my side, I will be posting back as soon as I have any update on the case.
Leonardo C.
Empleados
5.284 Vistas
Hello Jacky161
Thank you for waiting; Allow me to share with you that we have tested the game several times and ways, we can see some lagging, but it appears randomly and does not seems to be related to the Intel® graphics driver since they are not constant. Therefore, at this point, the reported issue is unrelated to our driver. Please use the latest driver version 24.20.100.6286 available at:https://downloadcenter.intel.com/download/27988/Intel-Graphics-Driver-for-Windows-10 https://downloadcenter.intel.com/download/27988/Intel-Graphics-Driver-for-Windows-10.
Thanks for providing this feedback and as usual we are always improving our drivers and products.
In case you have to install the drivers manually please refer to the following steps:
  1. Download the graphics driver ZIP file on the previous link.
  3. Right-click Windows Start icon and open Device Manager.
  10. Click "Browse".
  15. And let me know if you have any issues during the installation.
Leonardo C.
JLa1
Novato
5.284 Vistas
I just tried the newest driver and it is terrible on Fortnite. It's impossible to play at this point. It freezes for several seconds at a time and it's impossible to do anything in game. I'm not sure why the game doesn't lag on the old driver but does on the new driver. I'm not sure what I'm supposed to do at this point other than to just use the old driver.
Empleados
5.284 Vistas
Hello Jacky161
We have tested the behavior with 100 Mbps wired connection, Intel® HD graphics 620 (different diver versions from Intel® site latest and oldest), and 8GB of ram; we have got to the behavior reported on the previous post.
Also, take in consideration the Intel® graphics driver are the generic driver for the Intel® HD graphics controller on the system since the Original Equipment Manufacturer (OEM) would customize and personalize the driver that they provide (21.20.16.4494) for the Laptop system in this case you can contact the OEM for consult if there are newer driver for your system model, in addition to the divers you could consult for available bios updates or increasing the ram on the system for better performance.
Leonardo C.
Responder
