22662 Обсуждение
Games are laggier on my HD 4000 than HD 3000
Сотрудник
2 600Просмотр.
Hello.I have a problem.I have recently bought an ASUS VivoBook S200(X202e) with intel core i3 3217u.On my friend's laptop with HD3000 Need for Speed World and other games works on medium.I have lag on medium ,on low works fine.And I FOUND THE PROBLEM,but I can't solve it.The gpu doesn't rise from 350MHz to 1050MHz.It raises only to 650 MHz and extremely rare to 1050MHz.This can be a governor problem.But how to change the GPU Governor?(My GPU is already set on Maximum Performance).In Intel Extreme Tuning Utility I don't get a graphics tuning page...Maybe if I buy a Windows 8 ,other than the preinstalled will solve the problem??Even in windows experience index the score is lower than it is meant to be.Is only 4.4 on desktop graphics and 6.0 on gaming graphics.Thanks
0 баллов
5 Ответы
MSchm21
Ценный участник I
1 341Просмотр.
Try 9.17.10.2885 or 8.15.10.2761, it might improve this behavior.
BGroy
Начинающий
1 341Просмотр.
I've noticed this problem too with my HD4000. With GPU-Z running and testing with a game like Skyrim the GPU seems to drop to lower frequencies.
It seems to happen less often with the 2885 driver that people have been mentioning. The downside is that GPU acceleration gets disabled in Firefox with this driver. (The Firefox GPU acceleration status can be seen in about:support)
MSchm21
Ценный участник I
1 341Просмотр.
On ULV notebooks it depends also on power budget and cooling and not only on the driver itself. If a 15.26 or the 15.31 beta driver doesn't help, there not much you can do. You could try disabling SMT/CPU Turbo in the bios to give your graphics unit a bigger TDP headroom.
Сотрудник
1 341Просмотр.
Thanks for your help.The driver helped me a bit,because,as you write,it really make my gpu core clock less lazy,and i really see some more fps in games.Thanks.
Сотрудник
1 341Просмотр.
Anyway,does someone know why i don't see Graphics Tuning in Intel Extreme Tuning Utility?Thanks.
Ответить
