22760 Discussions
Games
ASeki1
При запуске игры MINECRAFT запускается на Интел Графике а видео карта пустует, помогает только отключение самой видеокарты Интел. В самом Инвидео стоит приорете на запуск с видеокарты но в данной игре графика Интел почему то берет приоритет.
n_scott_pearson
Is this a laptop? If so, talk to your laptop vendor. They are responsible for the drivers for your laptop's graphics.
AlHill
You have a laptop with dual graphics, correct? Are you using the drivers provided by the laptop manufacturer? If not, you should.
Doc
ASeki1
Да использую все драйвера от производителя. И обновленный BIOS
AlHill
Download, run, and ATTACH the results of this utility:
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility
Then, an intel support engineer can assist you.
Doc
ASeki1
Готово.
ASeki1
Более подробнее тут : https://ru-minecraft.ru/forum/showtopic-18579/ . Это русский фоурм по Minecraft
Wanner_G_Intel
Hello ASeki1,
Thank you for posting on this Intel Community.
To better assist you, please attach the missing information from the Template for submitting a Graphics bug
DxDiag* report:
1. Press WinLogo key + R.
2. Type “dxdiag” and press Enter.
3. Click on "Save All Information" and save it on your computer.
4. Attach the report to this thread.
Wanner G.
A Contingent Worker at Intel
ASeki1
ASeki1
posted a file.
ASeki1
posted a file.
Wanner_G_Intel
Hello ASeki1,
Thank you for your response.
We launched the game on a system with hybrid graphics, Intel® HD Graphics 630 + discrete graphics. We did not experience the behavior reported on this thread, which means that the problem you are having is not a driver issue.
Recommended steps:
1. With the Intel® HD Graphics enabled, try enabling/disabling NVIDIA* hardware acceleration and check the performance of the system (if applicable).
Additional information:
2. Where did you download the game from?
3. Were you able to launch the game with both integrated and discrete graphics enabled before?
Note: Our support is only provided in English. We may not be able to translate screenshots/files attached to the thread. To better assist you, we use a translation tool embedded on this Intel® Community.
Wanner G.
Wanner_G_Intel
Hello ASeki1,
If you need further assistance, please let us know. We will be glad to help you.
Wanner G.
Wanner_G_Intel
Hello ASeki1,
Were you able to contact your Original Equipment Manufacturer (OEM) to know if there is a way to disable/enable hardware acceleration?
We have not heard back from you, so we will close this inquiry. If you need further assistance, please post a new question.
Wanner G.
