23723 Discussions
Graphics driver BSOD
pashuuu
in shop when i go to buy this laptop it says it has iris xe graphics... and now when i come to home and now it says its graphics is intel uhd family graphics.. bro i brought new laptop cuz it has better graphics..help me please
Screenshot 2024-08-11 232404.pngScreenshot 2024-08-11 232404.pngIMG_20240811_231941.jpgIMG_20240811_231941.jpg
n_scott_pearson
Actually, I can answer this one. Only when you are running your memory in Dual-Channel, Fully-Interleaved mode will it appear as Xe graphics. If running in Single-Channel or Non-Interleaved mode, it will only appear as UHD graphics. Dual-Channel, Fully-Interleaved mode requires identical memory installed in both memory channels.
Hope this helps,
AlHill
So, is this a complaint about the graphics not being XE, or a BSOD which you provided no information about?
So the Intel support engineers can have more information about your system, Please download and run the Intel System Support Utility (https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows- ) for Windows. Select all data categories and then have it generate a report. Next, have the tool Save the report to a text file (don't try to use the Submit capability; it doesn't work). Finally, using the Drag and drop here or browse files to attach dialog below the edit box for the body of your response post, upload and attach this file to the response post.
[If you find any Intel driver you might need, download and save it now.]
n_scott_pearson
Hope this helps,
pashuuu
brot thanks for saying these things but can u tell me how to do that cuz i have no idea about that and when i cheack youtube there is no proper solutuins...bro
n_scott_pearson
For that, we need more information. Please download and run the Intel System Support Utility for Windows. When you start the utility, select Everything and then click on Scan. Once it completes the scan process, click on Next and then Save. Pick a name for the text file to create and click on Save to create it. You can then close the app. Finally, open a response post here and then, using the Drag and drop here or browse files to attach dialog (below the edit box for the body of your response post), upload and attach this text file to the response post.
