ok so, the temperature are normal in the range of 37/51°C this cpu ulv are very power efficient.
Hi Stephen88,
I would suggest you to get in contact with your computer manufacturer to see if your laptop is under the warranty, as they are more familiar with the total configuration of your integrated system and the way all the features interact with each other.
Please bear in mind that Intel sells parts to various OEM's (Original Equipment Manufacturers), who then integrate them with other system components (power supplies, disk drives, add in cards, software, etc). These parts may be customized to the OEM's specifications.
In this link you can access to acer® support.
http://www.acer.com/ac/en/US/content/support http://www.acer.com/ac/en/US/content/support
Hellen
temperature are not a problem, contact the manufacturer is useless because all E5-573 are mede like that, I did not conceive the reason to cut that piece of deliberately heatsink so as not to touch it graphics card.
Hi Stephen88,
Thank you to provide the right information; I am glad that your system is fine.
Hellen.
![](/skins/images/045A6C88D0527A93E76B179D7F5E2AFE/responsive_peak/images/icon_anonymous_message.png)
Topic Options
