- Отметить как новое
- Закладка
- Подписаться
- Отключить
- Подписка на RSS-канал
- Выделить
- Печать
- Сообщить о недопустимом содержимом
I'm sending a log file containing the messages from a failed driver installation and an 'event id 20' entry from the MSFT event log. Any help in resolving this would be appreciated.
Ссылка скопирована
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
Hello Cas-K,
Thank you for posting on the Intel® communities. I am sorry to know that you are having issues with your Intel® HD Graphics 630.
1. When did the issue start? Is it recent?
2. Are you using a laptop or desktop computer?
3. What is the operating system installed as well as the version and build?
4. Did you try to perform a clean installation of the drivers?
5. What is the brand and model name of your processor?
6. Are you experiencing any issues with the graphics besides the update?
Deivid A.
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
Have you looked at the two attachments? The event log gets an entry every time Windowsupdate runs, complaining about a failure to update the Intel video driver software - this happens everytime Windowsupdate runs. I really can't give you anymore information than the IntelGFX log has. I am running Windows 11 22H2 ( Build 22621.1105). I started getting these evnt log entries right after atempting the Intel driver update. I'm using a desktop and I'm not experiencing any video problems - I was simply trying to stay up with maintenance and felt that getting the latest update from Intel was the right thing to do. I'm attaching a section of MSinfo32.
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
Hello Cas-K,
Thanks for the response. Just to confirm the issue, please try the following:
1. TRy to perform the update using the Intel® Driver & Support Assistant:
2. Tr to perform a clean installation of the driver:
- Driver: https://www.intel.com/content/www/us/en/download/762755/intel-6th-10th-gen-processor-graphics-windows.html
- Steps: https://www.intel.com/content/www/us/en/support/articles/000057389.html
Deivid A.
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
I'm very leery of doing intel graphics driver updates - my system seems to have problems after these types of updates. I currently have two Intel updates: One is for a intel software component 20.100.0.0 and the other is for an intel extension 20.110.0. I'm going to remove these from the queue. I'm not having any problems with the driver 20.20.100.7986.
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
Hello Cas-K,
Thanks for the confirmation. If you would like us to investigate this issue further, besides the reports that you have sent, please provide the report from the Intel® System Support Utility (Intel® SSU)
- Download the Intel® SSU and save the application on your computer: https://www.intel.com/content/www/us/en/download/18377/intel-system-support-utility-for-windows.html
- Open the application, check the "Everything" checkbox, and click "Scan" to see the system and device information. The Intel® SSU defaults to the "Summary View" on the output screen following the scan. Click the menu where it says "Summary" to change to "Detailed View".
- To save your scan, click Next and click Save.
If you would not want us to investigate, just let me know.
Deivid A.
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
I'm sendimng you the information that you requested.
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
Ok, so what should I do ? I don't need any updates? What about 31.0.101.2115 ?
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
Hello Cas-K,
Thank you for the information provided
Deivid A.
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
My suggestion would be to do a clean install.
- Download - but do not install just yet - the new driver package from the Intel site. Here is link to download page: https://www.intel.com/content/www/us/en/download/762755/intel-6th-10th-gen-processor-graphics-windows.html.
- Very Important: Disconnect system from Internet. Unplug Ethernet cable and/or disable Wireless. Note: if using Wireless, it should be disabled in such a way that reboots can occur without it automatically re-enabling.
- In the Apps and Features applet, check to see if there is an Intel HD Graphics or Intel Graphics entry. If not, skip to Step 6.
- Click on the Intel HD Graphics or Intel Graphics entry and select Uninstall.
- Reboot the system, keeping Internet access disconnected.
- From Device Manager, check if there is an entry for an Intel Graphics adapter. If you see only the Microsoft Basic Display Adapter, skip to Step 9.
- Right-click on the entry for the Intel Graphics adapter and select Uninstall Device. Checkmark Delete the driver software for this device and then click on the Uninstall button.
- Go back to step 5.
- Install the new driver package that you downloaded in Step 1.
- Reboot the system.
- Reconnect Internet access.
- Test.
Hope this helps,
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
Hello Cas-K,
We are still investigating this issue with the driver installation. However, I would like to know if the steps provided by n_scott_pearson helped you and if the issue is fixed.
I will be waiting for the confirmation.
Deivid A.
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
I answered that everything is good. Mr. pearson's instructions bwere helpful and a 'clean' install was necessary to get around my Intel driver update problem.
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
Hello Cas-K,
Thanks for the confirmation, I am glad to know that the steps shared by n_scott_pearson helped you and fixed the issue. I will proceed to close this thread, however, you can open a new one in case you need further support or if you face any issues with our products.
Deivid A.
- Отметить тему как новую
- Отметить тему как прочитанную
- Выполнить отслеживание данной Тема для текущего пользователя
- Закладка
- Подписаться
- Страница в формате печати
