23586 Discussions
HD5500 240hz
CB10
Does the HD5500 support running a single monitor at 1920x1080, 240hz via mini displayport? I'm not using it to play games, just view 240hz content.
Hello cjbconnor,
Thank you for posting.
Please, let us know your computer model and processor model.
Amy C
Under Contract to Intel Corporation
CB10
The computer is a lenovo x250 with an i5-5300U
You need to double check with Lenovo what is the DP version included in your hardware. With that piece of information you can consider the following DisplayPort bandwidths:
The resolution you are interested to set will require approximately 14.93 Gbps of total Signal Bandwidth. In theory, depending on your DP version you could be able to set the resolution. But, you also need to check with Lenovo is this is a valid resolution for their hardware, I checked your computer specifications and this resolution is not listed.
For reference visit:
https://en.wikipedia.org/wiki/DisplayPort DisplayPort - Wikipedia
https://k.kramerav.com/support/bwcalculator.asp Bandwidth calculator - Kramer Electronics
http://psref.lenovo.com/syspool/Sys/PDF/ThinkPad/ThinkPad%20X250/ThinkPad_X250_Platform_Specifications.pdf http://psref.lenovo.com/syspool/Sys/PDF/ThinkPad/ThinkPad%20X250/ThinkPad_X250_Platform_Specifications.pdf
Amy C
