Windows 10 updated from 1803 to 1809. At that point, my second monitor was displaying at a wrong resolution. I went to the Intel HD Graphics Control Panel App. My saved profile which had been working was there, so I attempted to apply it. This caused some type of glitch and I got a blue screen with a happy face while the PC attempted to repair.
I then installed "Intel Driver and Support Assistant" and updated all offered drivers. It did update the graphics driver from 20.19.15.4474 (June 2016) to 20.19.15.5058 (Aug 2018).
I was advised to reboot, and the HDMI no longer detects any external monitor at all. Intel Graphics CP still has the profile but cannot apply it - the error is "the profile cannot be applied with the current system configuration"
The TV and two HDMI cables work with in either of the TV ports with two other Win 10 v1809 PCs (different manufacturer, so not same combination of Intel components)... I say this to confirm I have troubleshooted the monitor itself, cables, and ports.
"Roll back" the driver is greyed out, but I "updated" it back to the .4474 version; didn't help. Refresh rate is 59Hz or 60 Hz depending where you look (I understand the 60Hz is nominal only and it is *actually* 59.9 or something like that).
Neither of the Intel download pages for .4474 and .5058 show Intel HD 405 nor z-X8750 specifically in the list of supported. There is only mention of "Braswell/Cherry Trail" and "Intel HD" and 8700. Are these versions correct for my PC ?
In Device Manager, one of the Generic PNP Monitor entries greyed out. The errors is "not migrated due to partial or ambiguous match"
連結已複製
I have tried this method - NOT CONNECTED to internet, uninstall and remove driver files for the "Display Adapter", "Monitor", and "Sound, video, and game controllers". So I ended up with the basic or standard MS drivers only. Neither HDMI nor displayport worked with only the MS drivers. My UNSUCCESSFUL 4 attempts (CLEAN back to MS each time):
- Install Intel 5058 (previously downloaded, so still not connected to internet to prevent Windows from updating any drivers).
- Install PC manufacturers original driver pack (gave me Intel .4474 mentioned above) - didn't work, so then installed Intel .5058 over top (both previously downloaded)
- Connect to internet and let Windows install the driver - gave me Intel 4549 (Nov 2016) - didn't work, so then installed Intel .5058 over top
- Connect to internet and use "Intel Driver and Support Assistant" - it gave me .5058
No, it is well over 10 days since the update, so there's no easy reversal.
I do have backups, but hoping not to go down that road.
Won't Intel update HD 405 to be compatible with 1809 if this is the case?
Is this related? There is an "unknown device" under "Other devices" with an exclamation point:
The drivers for this device are not installed. (Code 28)
Under the Events tab, it refers to Intel SST
Management concluded the process to install driver isstrtc.inf_amd64_d9f5d3b38ff8b9b5 for Device Instance ID ACPI\808622A8\1 with the following status: 0x0.
My report is attached.
Can you confirm my understanding of this situation?
I have been reading articles that use the verbiage "required" ... as in the "modern" / DCH / "universal" drivers are *REQUIRED* as of Windows 10 v 1809 - that this is the new standard that MS has imposed. Intel has published a list using the following words" ONLY ... controllers listed below will ... update to ...DCH"
https://www.intel.com/content/www/us/en/support/articles/000031275/graphics-drivers.html
As the HD 405 is not in that list, I guess I am stuck with resetting my under one year old PC to factory status and ensuring it never updates any further than 1803. Why doesn't Intel have Microsoft BLOCKING this update when there is an older adapter that Intel will not support?
Wanner, I wish to thank your for your replies so far! Much appreciated.
I am still unclear on whether WIndows 10 1809 new driver type standard (DCH/DCHU/Universal) means that any items without new style drivers simply cease to function?! I have asked on WIndows 10 forums as well.
I have not a clue how to update firmware on TV or monitors. I did at one point, go back to the Ockel provided driver version, and it did not resolve the issues. I had actually been running with the later Intel driver (Intel DSA installed) AOK for several weeks prior to the Windows update.
Here's something new .. I got my hands on a USB-C adapter which includes a HDMI and a VGA port. The same TV and monitor and cables work thru that HDMI, and a VGA monitor works ... Windows detects either monitor and I can toggle between all the modes just fine (PC only, duplicate, extend, etc...) and I can manage those screens via the Intel graphics control panel software also. Attempting to plug back into the built-in HDMI port directly still fails to work. Is it possible that the adapter or the USB-C port has the proper DCH driver so it works doing to same work that the built-in ports fail to do ?
One thing that I thought of - after doing the Win 10 update, I ran the Intel DSA. Is it possible that it gave me a BIOS update or adjusted some settings in the BIOS? In this case, which setting(s) in BIOS should I verify that may be responsible for disabling the built-in external HDMI and Displayport ports ? I looked at the BIOS but nothing was obvious to me as to controlling these ports.
