23271 Discussions
Help PCI and "Other devices" are not installed (Code 28)
Jopaisan
I got blue sceen error : clock watchdog timeout. some video tell me checking device manager is the way to fix it and my other device have an error
all cant autometic update pls help. i didnt know where to find download
motherboard : ROG STRIX Z690-A GAMING WIFI
This is id.
PCI 1
PCI\VEN_8086&DEV_7ACE&SUBSYS_86941043&REV_11
PCI\VEN_8086&DEV_7ACE&CC_0C8000
PCI 2
PCI\VEN_8086&DEV_7ACD&SUBSYS_86941043&REV_11
PCI\VEN_8086&DEV_7ACD&CC_0C8000
PCI 3
PCI\VEN_8086&DEV_7AA4&SUBSYS_86941043&REV_11
PCI\VEN_8086&DEV_7AA4&CC_0C8000
PCI 4
PCI\VEN_8086&DEV_7ACC&SUBSYS_86941043&REV_11
PCI\VEN_8086&DEV_7ACC&CC_0C8000
Raid Controller
PCI\VEN_8086&DEV_467F&SUBSYS_86941043&REV_00
PCI\VEN_8086&DEV_467F&CC_010400
Sm bus controller
PCI\VEN_8086&DEV_7AA3&SUBSYS_86941043&REV_11
PCI\VEN_8086&DEV_7AA3&CC_0C0500
Unknown Device
ACPI\VEN_INTC&DEV_1056
ACPI\INTC1056
*INTC1056
Jean_Intel
Hello Jopaisan,
Thank you for posting on the Intel️® communities. We would be more than glad to help you.
Since you report that multiple devices need to be updated, we would recommend you install all the drivers from the ASUS website regarding your system. Please note that the best thing to do is to use the customized drivers provided by the system manufacturer (OEM) or through Windows Update to eliminate the potential impact caused by loading non-custom drivers.
However, if you would like to further troubleshoot the BSOD error you reported and discard that there is an issue with the processor, provide us with your CPU model.
Jean O.
Jean_Intel
Hello Jopaisan
We hope you are doing fine.
We wanted to confirm if you have been able to try installing the ASUS drivers, as we recommended before. If you require further troubleshooting regarding the BSOD problem, let us know,
Jean O.
Jean_Intel
Hello Jopaisan,
Unfortunatly, since we have not heard back from you, we will close this thread. If you need any additional information, submit a new question, as this thread will no longer be monitored.
Best regards.
Jean O.
