23587 Discussions
How to I get intel graphic control panel without microsoft store?
Loty3838
My Windows is Windows 10 64bit 1809 and I haven't got a microsoft store app.
My CPU is intel core i5 10300H 2.5ghz
AlHill
Are you using a DCH driver?  If so, the download is automatic.  Look under "I" in the start menu.
So the Intel support engineers can have more information about your system, Download, run, and save the results of this utility as a text file:
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility
Then ATTACH the text file using the instructions under the reply window ( Drag and drop here or browse files to attach ).
Loty3838
Yes I am using DCH driver but there isn't any file under the I on search.
I downloaded the SSI and the file is here.
Loty3838
AndrewG_Intel
Hello @Loty3838
In compliance with Microsoft® new Universal Windows Platform (UWP), Intel has stopped bundling the Intel® Graphics Command Center and the Intel® Graphics Control Panel with DCH Graphics Drivers.
UWP requires that all driver-dependent applications be made available only through the Microsoft* Store.
Based on the intel Intel® System Support report (Intel® SSU) we noticed that the system is running Windows 10 Enterprise LTSC (Long-Term Servicing Channel).
If you are facing challenges since access to the Microsoft* Store may be limited, for Windows 10 Enterprise or IoT Enterprise LTSC, Microsoft’s current recommendation is to use a Device Management solution until Device Update Center is made available by Microsoft:
https://docs.microsoft.com/en-us/windows/client-management/mdm/enterprise-app-management
For more information, please check this link:
Installing Intel® Graphics Command Center and Intel® Graphics Control Panel on Windows® 10 Long-Term Servicing Channel (LTSC) >> https://www.intel.com/content/www/us/en/support/articles/000055210/graphics.html
In this case, we recommend consulting directly with Microsoft* for further information on these solutions.
Andrew G.
*Links to third-party sites and references to third-party trademarks are provided for convenience and illustrative purposes only. Unless explicitly stated, Intel® is not responsible for the contents of such links, and no third-party endorsement of Intel® or any of its products is implied.
Loty3838
I Installed the App but ı got an error. When I try to open Graphic command center, the splash screen comes up and the app shuts down instantly.
When I try to open Graphic Control Panel I get an error. The error message is "gfxlauncher.exe the service failed to start"
AlHill
@AndrewG_Intel   This user has multiple threads, and is using a 10th gen processor.  He refuses advice:
https://community.intel.com/t5/Graphics/HOW-TO-I-GET-INTEL-GRAPH%C4%B0C-COMMAND-CENTER-W%C4%B0THOUT-US%C4%B0NG/m-p/1230358#M91719
Loty3838
Thanks :D:D:D
He already answer my question bye for you
AlHill
AndrewG_Intel
Hello all,
@Loty3838, since you mentioned our post has answered your question and considering the recommendation is to check this directly with Microsoft* support, we will proceed to close this thread now.
If you need any additional information, please submit a new question as this thread will no longer being monitored. Thank you for your understanding.
Andrew G.
