공지
22794 토론
How to disable "Display Power Saving Technology" for the plugged in laptop?
STimo1
초급자
4,833 조회수
Hello!:) Read several treads. Quite a few people have this issue, however couldn't find a solution to my one.
I turned it off in the Intel® HD Graphics Control Panel. While the laptop is running on battery, its fine. But the Display Power Saving Technology starts working again once the laptop is plugged in (I don't have an option in the Intel control panel to switch between battery and plugged-in modes). I updated drivers (used windows device manager, because the Intel(R) Driver Update Utility was not able to do so). Here is my info:
Windows 10 Pro
Lenovo yoga book
Cry for help: you cant even imagine how annoying it is to sit in a room full of light having a white page on the word doc open - and still get a very low brightness level. Please help!
0 포인트
6 응답
CCris2
새로운 기여자 II
2,705 조회수
Hi Santst ,
You should check the Power Options in Control Panel. Go to Change plan settings of the selected option and then Change advanced power options. There look for Display Options and you have an option there Enable Adaptive Brightness and you have to disable it.
Also you should check if you don't have an application from Lenovo active that controls power options. In that case you should check if it doesn't override the settings you make.
I hope you found this helpful.
0 포인트
직원
2,705 조회수
Hello Santst:
I just wanted to check if the information posted previously was useful for you and if the problem got fixed or if it still persists?
Alberto
0 포인트
STimo1
초급자
2,705 조회수
Hello Alberto,
I apologize for the delayed reply.
Unfortunately the problem still remains. The solution provided by Ronin does not solve the problem (I already have the adaptive brightness turned off). I have created a thread in Microsoft - currently waiting for a response. I have also contacted Lenovo support - they also suggested to turn off windows' adaptive brightness - since I already have it off, waiting for further help from them. Moreover, I did not find any Lenovo specific applications on my Yoga book.
I also installed one Lenovo application to try and solve the problem (Lenovo settings). However, it did not help. I still believe that the issues is in the intel control panel, as I was able to solve the problem for the battery mode.
I've seen screenshots. Some people have options for battery/plugged in.
Mine shows this - no options:
Kindest regards,
Stanislav
0 포인트
직원
2,705 조회수
Hello Santst:
No problem at all, we do know it takes time to try different troubleshoot steps.
Please try the following driver, it is version 4501, according to the released notes of the driver it is the proper one for your processor, you can check the released notes on the link below as well:
https://downloadcenter.intel.com/download/26228/Intel-Graphics-Driver-for-Windows-10-and-Windows-7-8-1-15-40- https://downloadcenter.intel.com/download/26228/Intel-Graphics-Driver-for-Windows-10-and-Windows-7-8-1-15-40-
Not sure if this is your laptop because there are different models for Lenovo Yoga Book, but you can try the following graphic driver:
http://support.lenovo.com/us/en/products/Tablets/Yoga-Series/YOGA-Book?linkTrack=Caps%253ABody_SearchProduct&tabName=downloads&beta=false http://support.lenovo.com/us/en/products/Tablets/Yoga-Series/YOGA-Book?linkTrack=Caps%253ABody_SearchProduct&tabName=downloads&beta=false
A BIOS update might be helpful in this case, here is the file to do it, but in you need assistance about how to do it, then the best thing to do is to verify those details with Lenovo directly:
Please let me know the results of trying the steps above.
Alberto
0 포인트
직원
2,705 조회수
Hello Santst:
I just wanted to check if you were able to do the BIOS update and install the drivers provided previously, and if the problem still persists or if it got resolved?
Alberto
0 포인트
직원
2,705 조회수
Hello Santst:
Thank you very much to for the information provided above.
To:
Please follow the steps provided above, you should be able to find the option to disable the "Display Power Saving Technology".
Also, if you still cannot find it that way, as an option you can get in contact with Microsoft directly in order to verify if there is another way to do that.
Besides that you can also get in contact with Lenovo in order to find out if there an application that controls power options.
Microsoft's phone number: 1 800-642-7676
Microsoft's support site: https://support.microsoft.com/en-us https://support.microsoft.com/en-us
Lenovo's phone number: 1-877-453-6686
Lenovo's support site: http://support.lenovo.com/cr/en/ http://support.lenovo.com/cr/en/
Alberto
0 포인트
응답
