22664 Discussions
I can't install the Intel DCH windows 10 drivers for the UHD 630 driver on my laptop. The error message I get is "This operating system is not supported", even though I'm running windows 10 build 1803 which is clearly listed as one of the supported OS
HFeng8
VARADHARAJAN
Valued Contributor II
​will you   share  your intel gpu  630  hardware ID  , then I will tell  whether its  supported or not
HFeng8
The hardware ID is PCI\VEN_8086&DEV_3E9B&SUBSYS_16531458&REV_00
VARADHARAJAN
try to type below commands and press enter
sfc /scannow
Dism.exe /online /Cleanup-Image /StartComponentCleanup
Dism.exe /Online /Cleanup-Image /RestoreHealth
restart the windows .
Use CCleaner to clean registry files an d junk files
try to update latest windows update build no 17134.472 ,
then try to type below commands and press enter
sfc /scannow
your hardware device ID is fully supported , i checked in the driver file
Now download the latest DCH_WHQL driver 25.20.100.6471 and install with admin rights
https://downloadmirror.intel.com/28435/a08/dch_win64_25.20.100.6471.exe
or this driver 25.20.100.6444
https://downloadmirror.intel.com/28148/a08/dch_win64_25.20.100.6444.exe
once completed installation , restart the windows
HFeng8
I've tried the above and got the error again:
" The driver being installed is not validated for this computer. Please obtain the appropriate driver from the computer manufacturer"
MJ287
I have the same problem, what if I can't update to the build. Will it still work.
MMohs3
