공지
22740 토론
I doesn't have the scaling option windows 11
Yep
초급자
2,128 조회수
Hello, when I was in windows 10, I had the option of scaling in the center of intel, now that I update to windows 11 I no longer appear, what has happened ?
0 포인트
3 응답
AlHill
수퍼 사용자
2,099 조회수
So the Intel support engineers can have more information about your system, Please download and run the Intel System Support Utility (https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows- ) for Windows. Select all data categories and then have it generate a report. Next, have the tool Save the report to a text file (don't try to use the Submit capability; it doesn't work). Finally, using the Drag and drop here or browse files to attach dialog below the edit box for the body of your response post, upload and attach this file to the response post.
[Windows 11 is the new Vista]
0 포인트
Yep
초급자
2,091 조회수
Yes, for sure, here you have it. By the way, windows did not let me upgrade to windows 11 for something of the processor, which was not compatible, I looked what processors were and there should be no problem, anyway I did a forced installation
0 포인트
AlHill
수퍼 사용자
2,087 조회수
Your processor is not supported by windows 11.
https://docs.microsoft.com/en-us/windows-hardware/design/minimum/supported/windows-11-supported-intel-processors
0 포인트
응답
