22667 토론
I keep getting random hangs on Core I7-2600k using Integrated graphics.
WHils
초급자
22,822 조회수
I purchased a few machines for myself and clients consisting of a Core I7-2600k and a Asrock H67DE3 Motherboard, 16GB memory running Windows 7 (Can give other specifications, but not sure if relevant).
I chose the H67 and a 2600k as overclocking is not that important but I wanted the 3000 graphics as it is meant to be better in the K variant.
When watching video or similar activities, at random, the system will just freeze for anything from 5 seconds (which happens frequently) down to around half an hour, the message that comes up is as follows:
I have only forcefully reset it twice when it hung for over 20 minutes and I needed to get on with work urgently. This is a log of the reliability monitor which shows this has been happening a lot! I am getting this around 5 or more times a day.
I purchased 4 machines for my clients and one for me. One of the people the machine was for was complaining of similar problems, and as they are a good client and I am known for reliability, I simply purchased 4 Nvidia cards and installed them just in case the other 3 develop similar problems - this seemed to fix the problem for them.
Whilst annoying for myself, I was ok with it, until yesterday, it froze whilst copying to a USB stick and it made the stick corrupt.
However, I would really like to get this resolved for mine and possibly revert back to the built in graphics for the client (bit useless having the K model CPU on a board that doesn't support Overclocking whilst not using internal graphics!)
I was 99% sure it was a driver issue, but during the last freeze, I tried pressing the reset button and nothing happened (power button worked as normal). - I am not sure if this is relevant - now that the machine is EFI and not standard BIOS, I thought it is possible that basic functions such as this are handled differently.
I originally purchased Sandy Bridge machines with the problem chipset - these were all to replace those and I do not feel confident in the platform at the moment!
The problem could be with : Driver (still personally what I think, but I could be wrong), Motherboard or cpu.
In case it helps, here is the detailed log from Reliability monitor after it has recovered.
Description
A problem with your video hardware caused Windows to stop working correctly.
Problem signature
Problem Event Name: LiveKernelEvent
OS Version: 6.1.7601.2.1.0.256.1
Locale ID: 2057
Files that help describe the problem
WD-20110428-1949.dmp
sysdata.xml
WERInternalMetadata.xml
View a temporary copy of these files
Warning: If a virus or other security threat caused the problem, opening a copy of the files could harm your computer.
Extra information about the problem
BCCode: 117
BCP1: FFFFFA801A3A84A0
BCP2: FFFFF88004A1D8F0
BCP3: 0000000000000000
BCP4: 0000000000000000
OS Version: 6_1_7601
Service Pack: 1_0
Product: 256_1
I hope someone can help, this is a very frustrating problem!
0 포인트
35 응답
직원
13,902 조회수
dude i am having problems with the intel HD graphics on my laptop too. Not getting any answers yet. Better if possible get it refunded and get the older version chip and save yourself time and headache. This is exciting new technology but bound to have tons of hiccups.
WHils
초급자
13,902 조회수
I got a call from Intel and was told it is most likely a driver issue and that I should be using the Asrock provided driver.
The Asrock driver has issues when running at 1080p making it completely unusable.
Intel released updated drivers a few days ago but when I tried them, the crashes become MUCH more frequent, however, upon recovering, it did not state that it was a graphics crash - but that is still my assumption.
I have now downgraded to 8.15.10.2342 and again, seems to only crash when doing graphical activities... but this is by far not ideal.
I am very annoyed as I only got a 2600k for the graphics as I did not want to overclock. If I change to a graphics card, not only will it use a lot more power (which I wanted to cut down on), it would be a waste having the K variant. I am considering switching to a p based board, but I am not very happy at all.
0 포인트
WHils
초급자
13,902 조회수
I am so fed up and getting no where! The last update which I was waiting ages for made it much worse - random crashes every 20-30 seconds and I had to roll back.
I am now no longer selling this configuation and recommending others to do the same.
http://blog.williamhilsum.com/2011/05/recommend-against-intel-core-i7-2600k.html http://blog.williamhilsum.com/2011/05/recommend-against-intel-core-i7-2600k.html
0 포인트
ROBERT_U_Intel
13,902 조회수
It appears this may be related to another issue we are currently working to resolve, /thread/20439?start=165&tstart=0 http://communities.intel.com/thread/20439?start=165&tstart=0 . We are currently testing a driver fix and should be able to post it to Download Center in the next few weeks.
0 포인트
직원
13,457 조회수
Robert, can you please confirm:
1. Timeline for the driver update
2. What is the level of confidence about the fix?
3. Is this only an ASRock issue? I have a brand new build, and would prefer to change to a different motherboard provider if that would resolve the issue
Cheers.
0 포인트
직원
13,457 조회수
I'm just gonna have to point finger at Asrock here. Page 1 has the Asrock H67, and rest of the posts as Asrock Z68. Intel H67+2600K, no crashes since Jan 2011, which is the release month and close to when I bought the CPU.
0 포인트
직원
13,457 조회수
Thanks David. I'm returning the ASRock and getting an ASUS Z68 motherboard instead. Hope it treats me better!
0 포인트
Allan_J_Intel1
13,902 조회수
Hi there!
If you are receiving this error "Your system has recovered from a serious error", please check below for possible solution.
http://www.intel.com/support/graphics/sb/cs-009483.htm?wapkw=%28OCA+graphics%29 http://www.intel.com/support/graphics/sb/cs-009483.htm?wapkw=%28OCA+graphics%29
Basically, you need to download and install the latest graphics driver. For your information latest version posted is 8.15.10.2361
If you need additional details about installing generic drivers, try this link
http://support.intel.com/support/graphics/sb/CS-022355.htm http://support.intel.com/support/graphics/sb/CS-022355.htm
Allan.
0 포인트
직원
13,902 조회수
I have the exact same issue with my i5-2400 and H67 as the original poster. The problem is so severe that I'm forced to use a dedicated video card whereas, similarly to wilhil, I switched to SB in order to save on the electricity bill (among other things of course). I hope you'll find a solution and fix the driver soon because the current situation is unbearable.
0 포인트
직원
13,901 조회수
same problem here with an core i3-2100.
also asrock h67de3 mainboard and 2* 4GB Gskill DDR3.
0 포인트
MSchm21
소중한 기여자 I
13,901 조회수
What Mainboard Bios version are you running?
I have a similar system and not such issue.
0 포인트
직원
13,902 조회수
1.40 newest version
updated from 1.2 where i had the problems, too.
all drivers are up to date.
0 포인트
직원
13,902 조회수
I support the thread. Have the same Issue.
Using 2600K HD3000 Graphics on ASRock Z68Pro3-m Mainboard. 8GB G-Skill RAM. Get hangs mostly browsing.
Please try 1080p youtube music + scrolling and fast zooming in google maps with landscape enabled if weird sound errors occur.
Also sorry that I started a new thread about this issue before I found this one here.
cheers,
kapi
0 포인트
직원
13,901 조회수
It seems the problem might be related to specific motherboards when using the integrated graphics, rather than the graphics driver itself. I use 2600K's HD3000 graphics on the Intel DH67BL board, and didn't get problems you guys said quoted.
Core i7 2600K
DH67BL
Dual Channel kit 4GB Corsair XMS DDR3-1600 running at 1333MHz
Intel X25-M main drive + Seagate 7200RPM secondary
Windows 7 64-bit Home Edition
0 포인트
직원
13,901 조회수
ASRock Z68Pro3-M with latest bios and Intel drivers from MS update (driverid=20418702). Get the following when I try to run Windows Experience Index.
SourceWindowsSummaryVideo hardware errorDate23.06.2011 22:42StatusSolution availableDescriptionA problem with your video hardware caused Windows to stop working correctly.Problem signatureProblem Event Name: LiveKernelEventOS Version: 6.1.7601.2.1.0.256.48Locale ID: 1044Extra information about the problemBCCode: 117BCP1: FFFFFA8009C194E0BCP2: FFFFF880048348F0BCP3: 0000000000000000BCP4: 0000000000000000OS Version: 6_1_7601Service Pack: 1_0Product: 256_1Bucket ID: X64_0x117_Tdr:2_IMAGE_igdkmd64.sysServer information: 07021d24-25fe-4486-8faf-b28aa6ac6c88
Log with h/w details have been posted to MS. They are investigating the issue.....
My solution to the problem was to install a PCI express card. 😛
Looks like HD3000 need som time maturing. Hope it is not another recall issue.
0 포인트
직원
13,901 조회수
There was a new bios update out for ASRock Z68 Pro3-M today.
1.30 6/24/2011 3.23MB Update CPU code.
"Update CPU code" doesn't say much but anyway my rigg managed to run through Windows Experience Index test without making the display driver hang. 🙂 A run through Passmark performance test revialed that they have crippled the 3D engine. "Graphic 3D - Complex" dropped from 42.8 to 1.64 frames/s.
0 포인트
직원
13,456 조회수
Hi
I updated my Asrock Z68 Pro3-M with the 1.30 Bios too.
I had no 3d performance loss, but I tested it only with 3dmark 2003. (9580 Points)
Intel Driver keeps resetting. (Version 2361)
0 포인트
직원
13,901 조회수
Hello.
I have the same problems under Windows 7 SP1 x64 and it's very frustating. Severel freezes more times a day.
Freeze during Copy or using a Virtual machine can result in data loss/corruption.
The freeze occurs randomly:
Sometimes surfing in Firefox, Sometimes gaming and last time after a fresh boot during Windows Performance Index measureing.
I tried several generic Intel Driver Versions (2291, 2347, 2361, 2401) with no Luck.
Also the manufactor driver from Asrock (2361) has the same issues.
I also did powercfg /hibernate off because I thought its a Standby/Hibernation problem.
Windows problem solution told me that HP is interested about this error. Windows opened this link https://www.hpwebgen.com/questions.aspx?id=20401&pass=7508 https://www.hpwebgen.com/questions.aspx?id=20401&pass=7508 and I reported it in their webform '0x117 Intel Timeout Driver Restart'
My specs are:
Mainboard: Asrock Z68PRO3-M Bios 1.20 no Overclocking.
CPU: I7-i2600 Stepping 7 Revision D2
Video Bios: 2111.0
Memory:Team Group Inc. Team-Elite-1333 4x4Gb
HDD: 1xSamsung HD322GJ, 1xSamsung HD103SJ, Intel Sata AHCI Controller with Driver 10.5.0.1026
PSU: Bequiet Straight Power E8-450W
Dump File : WD-20110615-2140.dmp
Crash Time : 15.06.2011 21:46:02
Bug Check String :
Bug Check Code : 0x00000117
Parameter 1 : fffffa80`13dc0010
Parameter 2 : fffff880`05038800
Parameter 3 : 00000000`00000000
Parameter 4 : 00000000`00000000
Caused By Driver : igdkmd64.sys
Caused By Address : igdkmd64.sys+1d800
Processor : x64
Crash Address : watchdog.sys+a577
Processors Count : 8
Major Version : 15
Minor Version : 7601
Dump File Size : 1.101.066
I hope too that someone can help.
0 포인트
직원
13,901 조회수
I already posted to tell that I have the same problem. Still not solved.
However I think I am able to reproduce the error anytime I want. I was just using a Blender file for 3D modeling and for some reason I get the display driver error every time I try to modify the model. Blender uses openGL only. I am listening to online music at the same time - if that matters.
If there is some way to record the bug or error I would be happy to deliver. Maybe that would help someone to help us.
greetings,
groten
0 포인트
직원
13,902 조회수
(Please make a Systemrestore Point / Backup before testing this. No responsiblity for this information. It worked for me since 2 days.)
I did the following:
I deinstalled all Intel Management Engine Software,
then went into the controlpanel -> System -> Device Manager and choosed Intel Management Engine
(Device ID something with PCI\VEN_8086&DEV_1C3A) in the Systemdevices category and deinstalled the driver.
Now I have an Unknown Device, which I wanted.
Without Intel Management Engine my Computer doesn't clock down the CPU anymore, but now I have 2 days without freezes / Graphic Driver resets.
Again. Please make a backup before uninstall anything.
Sorry for my english, but It's not my native language and I have a german Windows 7. I hope I translated it correctly.
If somebody wants to test this too, I would be happy to hear your positive or negative report and your testing method (uninstall or deactivate).
Update 20.06.2001 16:36 : Today I had a driver reset, but I saw that I had two Intel(R) Management and Security Application Local Management Services running (LMS and UNS). I deactivated and stopped them now, but I was wondering because I deinstalled the Software and the Services were still running. Deactivating the Intel Management Engine in the Device Manager doesn't seem to help, because I installed (for testing purpose) the Software again (And had immediately a Graphic Driver Reset.) but the Management Engine Device Driver didn't install. So I guess the Software and after deinstalling the 2 services caused my 2 driver Resets.
Greetings,
Kukki
0 포인트
응답
