공지
22754 토론
IGCC Combine monitors not working if a monitor orientation is Flipped
Adrian_Vasile_C_
초급자
5,228 조회수
Hello
I am trying to combine my two monitors (in portrait mode) into one.
With my hardware I have to use flipped orientation for the left monitor, because the viewing angle matters for this monitor.
When I combine monitors in the Graphics Command Center,, the command appears to work but the resulting orientation of my monitor is wrong. The image is no longer flipped.
That is, the Combine Monitors command ignores the flipped orientation and there is no way and no alternative to explicitly specify this orientation when using Combine Monitors command from the menu.
Can this be fixed please ? Is there a way to combine monitors with flipped orientation ?
0 포인트
21 응답
Mike_Intel
중재자
5,102 조회수
Hello Adrian_Vasile_C _,
  1. When did you purchase the unit?
  2. Was it working fine before?
  3. What are the troubleshooting steps that you tried?
Michael L.
0 포인트
Adrian_Vasile_C_
초급자
5,045 조회수
Hello
The order for my monitors was placed August 30 , 2024, at an online store in my country.
I never had a Flipped orientation for my monitors before, so this is the firs time.
I tried the Combine Monitors command with both vertical and horizontal options, hoping I can rotate the combined screen afterwards from Windows Settings. But there is nothing I can do if the monitor is no longer Flipped after the Combine command.
Thank you,
Adrian Vasile Constantin
0 포인트
Mike_Intel
중재자
4,978 조회수
Thank you for the update.
Just to check, what is the refresh rate that you used for the 2 monitors?
Michael L.
0 포인트
Adrian_Vasile_C_
초급자
4,934 조회수
Refresh rate is 144 Hz on both monitors
0 포인트
Mike_Intel
중재자
4,836 조회수
Please check the link below and follow the recommendation.
https://www.intel.com/content/www/us/en/support/articles/000059307/graphics.html
Michael L.
0 포인트
Adrian_Vasile_C_
초급자
4,795 조회수
Hello
I set my monitors to 60Hz and to Landscape orientation, as instructed in the link you provided.
Adrian_Vasile_C__0-1730827605494.pngAdrian_Vasile_C__2-1730827793113.png Adrian_Vasile_C__1-1730827644448.png
But IGCC still has the same problem:
After I combine the monitors, my flipped monitor is no longer flipped, and the image now appears up-side-down:
(I can see the monitors appear to be back in portrait mode, but I did not make the setting (I kept them in landscape mode). IGCC shows them like this after Combine....)
0 포인트
Mike_Intel
중재자
4,677 조회수
Upon checking the SSU logs that you posted, your Graphics driver is not updated.
Here is the latest driver for your Graphics controller. Try to install it and check if updating the driver will work.
https://www.intel.com/content/www/us/en/download/785597/intel-arc-iris-xe-graphics-windows.html
Michael L.
0 포인트
Mike_Intel
중재자
4,591 조회수
Michael L.
0 포인트
Adrian_Vasile_C_
초급자
4,585 조회수
Hello
I have installed the new driver and attached new SSU and IGCC reports.
Again I put both monitors in Landscape mode and 60Hz, but the behavior is still the same. The problem is still there:
My flipped monitor shows up up-side-down (no longer flipped) after I use IGCC to combine monitors
0 포인트
Mike_Intel
중재자
4,224 조회수
I will do further research on this matter and post the response on this thread once it is available.
Have a fantastic day, and thank you very much for your patience and understanding!
Michael L.
0 포인트
Mike_Intel
중재자
4,128 조회수
Thank you for waiting.
Upon further checking the details that you provided, I noticed that the monitor is in reversed (right side) that's why the output is in the wrong place.
And also, let me remind you that Combined mode is possible only with refresh rates up to 60 Hz and in landscape mode only.
Michael L.
0 포인트
Adrian_Vasile_C_
초급자
4,098 조회수
Of course I know the monitor is reversed. But I am supposed to keep it that way.
The LCD panel must be viewed from the appropriate angle. If I rotate it the other way, all the colors get distorted, making the monitor unusable.
So can you help me with the flipped orientation please ?
Yes, I used landscape mode and 60 Hz, here are some new screenshots, but after Combine Monitors in IGCC the image still looks bad.
Adrian_Vasile_C__0-1732116505052.png  Adrian_Vasile_C__2-1732116692368.png  Adrian_Vasile_C__3-1732116929365.png
The image looks right befre I use Combine Monitors in IGCC, if I configure the reverse monitor in Landscape (Flipped )orientation in Windows.
But right after Combine Monitors, my reverse monitor is suddenly up-side-down, though it was upright before
I can see the monitors appear to be back in Portrait mode in the photo, but I always  kept the Orientation settings to Landscape and Landscape (Flipped), as can be seen in the screenshots. But IGCC will show the monitors back in portrait mode after I use the Combine Monitors options
Can you still help me please ?
0 포인트
Mike_Intel
중재자
3,955 조회수
Base of the website that I provided before, Combined is not available for displays in portrait orientation.
However, let me still check what I can do with your configuration. Let me try this in our lab and update you on this thread once it is available.
Thank you very much for your patience and understanding!
Michael L.
0 포인트
Mike_Intel
중재자
3,851 조회수
I've successfully simulated the issue and found that the flipped function is still available in IGCC BETA. It was removed in the IGCC (main stream)
Please try to follow the steps below:
  1. Download the Intel® Graphics Command Center (Beta)
  2. Open the newly installed Intel Graphics Command Center (Beta).
  3. Go to Display.
  4. Select the monitor with the flipped display.
  5. Go to Rotation and adjust the screen rotation.
Michael L.
0 포인트
Adrian_Vasile_C_
초급자
3,766 조회수
Thank you,
I installed IGCC Beta and I set the monitor Rotation to "Landscape (Flipped)" like in the image.
But the behavior is still the same. When I combine monitors, my flipped monitor appears up-side-down, just like before.
0 포인트
Mike_Intel
중재자
3,645 조회수
Can you try to uninstall the IGCC and the IGCC(Beta) and the drivers using DDU. Then install the IGCC(Beta) and driver and try it again using 60hz settings:
https://www.intel.com/content/www/us/en/support/articles/000091878/graphics.html
Michael L.
0 포인트
Mike_Intel
중재자
3,574 조회수
Michael L.
0 포인트
Adrian_Vasile_C_
초급자
3,553 조회수
Sorry but I think using DDU to install such an old version of IGCC (that is still wrongly called Beta) is not going to help me.
The latest IGCC also shows my monitor as Flipped, so it knows, the issue is it just doesn't matter once I click Combine Monitors...
I recently received a new driver update from Intel DSA (for new version 6310 I belive), but the new driver still does not fix my issue.
I was hoping you can eventually send this issue to the engineering team, that can actually implement the feature that is so obviously missing.
Now I will just have to swapp my grafix card with an AMD one; a quick search seams to show they can do Flipped orientation.
But I was so enthusiastic about my new Intel GPU ... 😞 😞 😞
0 포인트
Adrian_Vasile_C_
초급자
3,039 조회수
Another Arc driver update from Intel DSA, and still the same old problem, can not combine a monitor with flipped orientation ... but now I got my new card.
And my new card, no longer from Intel, was able to properly combine my monitors, including my flipped monitor, from the first try, with a single click (Quick Setup), in portrait mode and at 144 Hz.
That is no limitations, no nothing, just worked and it did exactly what users would expect.
Watch and learn, Intel !
0 포인트
Mike_Intel
중재자
2,897 조회수
Base on the link that I provided before which is Link. Portrait mode is currently unavailable. We are actively working on adding this feature to the Intel Graphics Software, but we do not have an estimated time of arrival at this moment.
Because of this, I need to close this inquiry.
Michael L.
0 포인트
응답
