- Отметить как новое
- Закладка
- Подписаться
- Отключить
- Подписка на RSS-канал
- Выделить
- Печать
- Сообщить о недопустимом содержимом
My Laptop started freezing randomly lately I ve tried everything but nothing worked , until I found out that my pc works fine when I disable the intel uhd graphics 620 driver.
Even tho it works fine but I cant use a lot of programs and games and even my browser lags when I enable graphic accelerating.
please I need help.
Ссылка скопирована
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
Hi Yassine00,
Thank you for posting in the community. I want to set expectations regarding your situation. Since you are using a laptop, it may be an Original Equipment Manufacturer (OEM) model. If that's the case, I can only offer general troubleshooting advice. If the issue persists after trying these steps, I recommend contacting your OEM for further assistance.
To help us investigate the freezing issue on your laptop, I have a few questions:
- Could you provide the exact model of your laptop?
- What troubleshooting steps have you already completed?
- Has a clean installation of the graphics driver been part of your troubleshooting process?
- Have you used Display Driver Uninstaller to completely remove the graphics driver before installing a new one?
- Does the system freeze even when your laptop is idle?
- Have you checked if overheating might be causing the freezing issue?
- Do the fans on your laptop become quite noisy after prolonged use?
- When was the last time you cleaned your laptop?
- Have you contacted your laptop manufacturer for further assistance?
Dhanniel M.
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
Hi Yassine00,
I hope you've had a chance to go through the questions I shared. When you have a moment, please let me know so we can plan the next steps to resolve this matter efficiently.
Dhanniel M.
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
Hi Yassine00,
Dhanniel M.
- Отметить тему как новую
- Отметить тему как прочитанную
- Выполнить отслеживание данной Тема для текущего пользователя
- Закладка
- Подписаться
- Страница в формате печати
