Bonjour,
Existe t_il un intérêt à installer une carte graphique INTEL ARC 750 sur une carte mère déjà pourvue d'un processeur INTEL I7 12700 K (intégrant une partie graphique UHD 770) ?
En attendant de vous lire, recevez mes meilleures salutations,
Hello Castet33,
Thank you for posting in the Intel Communities. We would be more than glad to help you. First, we would like to inform you that our support is only provided in English. To better assist you, we use a translation tool; hence, the translation may not be completely accurate.
Before we proceed with assisting you, could you please provide more details about your query? We want to fully understand your question before providing further support.
If you are looking for advice on whether to purchase the INTEL ARC 750, we encourage you to make that decision based on your personal preference. While we cannot decide for you, we suggest conducting additional research on the product to inform your decision. You may find the following articles helpful:
- What Is the Difference Between Integrated Graphics and Discrete Graphics?
- Intel® Arc™ Graphics Overview
Jean O.
Hello Castet33,
We are jumping in the thread to check if the information we have shared in our previous post has been helpful for you. However, in case the information is not related to your question, please provide us with more details about your query.
Jean O.
Hello Jean,
Will the performance be increased ?
Or is it useless to cumulate two GPUs (integrated and dedicated) on the same motherboard ?
1) I buy only processor with integrated GPU I7 12700 K
2) I buy processor with integrated GPU I7 12700 K plus an INTEL ARC 750 graphics card
2) I buy processor without integrated GPU I7 12700 KF plus a graphics card INTEL ARC 750
I would like to know what would be the best solution to have the best performance.
For now I only use one 32" screen.
Hello Castet33.
It would be important that this decision will depend on your needs and your system use case. However, you should consider since discrete graphics have their memory source and power source, they provide higher performance than integrated graphics.
If you combine Intel Arc + Intel Integrated graphics (12th gen processor and newer), you can take advantage of Intel® Deep Link Technology. Having integrated graphics may also help you for troubleshooting purposes.
You can also use Windows Hybrid graphics wherein the GPUs and their drivers can be simultaneously utilized to provide users with the benefits of both the performance capability of discrete GPU (dGPU) and the low-power display capability of the processor GPU (iGPU). However, you should consult with Microsoft support for additional information about the system requirements to use this feature.
Hopefully, this information helps you, and we recommend you make the decision based on your system needs.
Jean O.
Hello Castet33,
Since we have not received a response from you, we will proceed to close this thread. We hope that the information we have shared helped you to make a decision. If you require further information, open a new thread as this one will no longer be monitored by Intel.
Jean O.
