22643 Diskussionen
Installation failed with error code 999
Bedtown
Einsteiger
1.219Aufrufe
Would like ask for your help as I encountered error 999 when trying to download the Intel® Graphics Driver 32.0.101.7026. Attached is the detailed report for your reference.
The issues started yesterday, I had actually installed it before successfully but  the problem I was trying to fix was not resolved by doing so. As such I tried to do it again and well... now we're here.
I haven't tried any troubleshooting issues before as I don't know any of them.
I have used DDU to remove any residual drivers, that's how I got here in the first place.
1 Lösung
Mike_Intel
304Aufrufe
Hello Bedtown,
Thank you for the update.
Since you are having issues with Intel DSA, kindly try to download and install the latest driver manually.
Please download the latest driver in the link below and tell me if this will fix the issue.
Intel® Arc™ & Iris® Xe Graphics - Windows*
Michael L.
Lösung in ursprünglichem Beitrag anzeigen
5 Antworten
Mike_Intel
905Aufrufe
Hello Bedtown,
  1. What is the model of the Graphics controller?
  2. What is the model of your processor?
  3. Are you trying to update the driver using Intel DSA?
  4. Aside from the driver issue, are you having other issues with the Graphics?
  5. For me to review the hardware and the drivers installed, please help generate the SSU logs of your system. Please refer to the link below on how to generate the logs:
Michael L.
Bedtown
Einsteiger
874Aufrufe
1. Intel R Iris Xe
2. 12th Gen Intel(R) Core(TM) i7-1265U (1.80 GHz)
3. Yes I am
4. No other issues
Mike_Intel
305Aufrufe
Hello Bedtown,
Michael L.
Bedtown
Einsteiger
268Aufrufe
Okay installing this driver worked fine, wish I knew what the error was such that it never appears again but both this error and what sent me here in the first place have been fixed.
Mike_Intel
111Aufrufe
Hello Bedtown,
Thank you for the update and I am glad that the issue is now fixed.
Since the thread is now tagged as "Solved", I need to close this inquiry.
Michael L.
Antworten
