22657 Discussions
Installed latest driver update for the b580 and now my monitor has a green tint
Dotce
For some reason there is a select few colors that now have a green tint
Ive reinstalled the drivers
Ive restarted my computer
Ive unplugged my monitor and plugged it back in
Ive shut off my monitor and turned it back on
Ive tried using an older version
wondering if someone else has a solution or possible solution I can use
Most solutions ive found online do not connect with my current issue
ArchieD_Intel
Hi Dotce,
  1. What type of connection are you using between your monitor and computer?
  2. Could you confirm the exact version of the driver you installed?
  3. Have you checked your graphics settings to ensure that color profiles or settings haven't been altered during the update?
  4. Can you share a photo or video of the issue?
  5. If possible, could you try connecting a different monitor to see if the issue persists? This will help determine if the problem is with the monitor itself or the computer.
  6. Please help generate the SSU logs of your system. Kindly refer to the link below on how to generate the logs:
Archie D.
ArchieD_Intel
Hi Dotce,
Did you have a chance to review the previous post?
Please feel free to reach out if you have any questions. Thank you.
Archie D.
ArchieD_Intel
Hi Dotce,
Archie D.
