22956 Discussions
Intel HD 3000 Graphics - Maintain Display Scaling Doesn't Work Properly
copying this from reddit, cba
I'm trying to play CSGO (Note: not CS only issue, the issue is there with every single program and even with desktop when using 4:3 resolution) with black bars (no stretching). When I select maintain display scaling, it doesn't actually properly maintain the scaling. The resolution doesn't feel as if it was 4:3, but as if it was 5:4 (Well, not quite). The image is stretched a bit upwards and is narrower on the sides than it should be. I can tell that from the fact that the games I run have upwardly stretched huds and the games feel weird aswell. Also like 1-2 millimeters of screen is actually missing from the bottom and top when using 4:3 resolution. I'm using the latest drivers HP has provided. I was wondering if there's like any registry keys I could edit or something like that, since the issue is quite a bit annoying.
Thanks!
EDIT: I've tried reinstalling the drivers quite a few times. I didn't have this issue with Windows 10 (Using Win7 right now). I tried using 1024x768 and I selected "Center Image". Everything is properly scaled when using that option, but the thing is that I don't use 1024x768 since my laptop isn't that powerful. I want as many frames as possible, so I use 640x480 or 800x600 instead.
Hi Flaggoz,
Would you mind fill out the information asked on this site?
/thread/77761 https://communities.intel.com/thread/77761
Also could you please attach the result of the Intel Graphics report?
http://www.intel.com/content/www/us/en/support/graphics-drivers/000005848.html http://www.intel.com/content/www/us/en/support/graphics-drivers/000005848.html
This is to further assist you.
Hellen.
Hi Flaggoz,
I would like to know if there is any update regarding the information requested previously.
Hellen.
Bryce__Intel
The fix to resolve black bars (Scaling) in gameplay and applications was delivered for 3rd Generation platforms and newer. Unfortunately a fix for 3rd Generation including HD 3000 is not available and support for 3rd Generation graphics has ended.
