23769 Discussions
Intel HD Graphics 520 Restarting daily
CMurr4
We have a few Dell Latitude E5570's all with the Intel HD Graphics 520. The driver restarts while scrolling in Citrix, Internet Explorer, Excel. I have tried every variety of drivers that Dell and Intel have without luck including the beta. I have disabled the TDR and it still will restart the driver. Please assist.
Hi murray.christopher,
Let's try to narrow down the issue. Verify with Dell support website if your laptop has the latest BIOS and main drivers (Chipset and Management Engine). Then, uninstall and delete the current Intel® graphics driver, restart the computer and finally install the latest graphics driver provided with Dell support.
http://www.dell.com/support/home/us/en/19/product-support/product/latitude-e5570-laptop/drivers http://www.dell.com/support/home/us/en/19/product-support/product/latitude-e5570-laptop/drivers
Intel provides with generic drivers; however, pre-build systems require a customized driver by the laptop manufacturer.
Mike C
CMurr4
I have 2 systems that I am working with. One has the newest dell drivers, the latest BIOS and other than that it is a basic system. And it does have the same issues. The other system is the one where I have tried the variety of drivers from Dell and Intel. It also has the latest BIOS from Dell. The issue still happens on both systems.
CMurr4
Here is the info on the systems. Dell just released an updated BIOS yesterday, 1.05, so I will try that today, but nothing in the fixes state anything for Video.
System 1
Latitude E5570
CPU Chip Count: 1
CPU Core Count: 2
CPU0: Intel(R) Core(TM) i3-6100U CPU @ 2.30GHz (2 cores)
4 GB
BIOS Date: 03/14/16 12:16:25 Ver: 1.4.7.00
Dell HD 520 Video Card Driver
System 2
Latitude E5570
CPU Chip Count: 1
CPU Core Count: 2
4 GB
Intel Beta HD 520 Video Card Driver
Let see how your laptops work with the latest BIOS.
Mike C
CMurr4
The updated BIOS makes no change.
Please download and run our Intel® System Support Utility tool and send me the results. With this information I will try to replicate the issue.
Available in the link below
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility?product=91600 https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility?product=91600
Tell me if you are getting the issue with a specific software.
Mike C
CMurr4
Here are the results I received from just scanning the Display
Adapter Compatibility Intel Corporation
Adapter DAC Type Internal
Adapter RAM 1.00 GB
Availability Running or Full Power
Bits Per Pixel 32
Caption Intel(R) HD Graphics 520 http://www.intel.com/content/www/us/en/search.html?keyword=HD+Graphics+520 http://www.intel.com/content/www/us/en/search.html?keyword=HD+Graphics+520
CoInstallers igfxCoIn_v4404.dll, CoDeviceInstall
Color Table Entries 4294967296
Dedicated Video Memory Not Available
Driver igdkmd64.sys
Driver Date 03/02/2016 04:00 PM
Driver Path C:\windows\system32\DRIVERS\igdkmd64.sys
Driver Provider Intel Corporation
Driver Version 20.19.15.4404
INF oem8.inf
INF Section iSKLD_w7
Install Date Not Available
Installed Drivers igdumdim64.dll,igd10iumd64.dll,igd10iumd64.dll,igdumdim32,igd10iumd32,igd10iumd32
Last Error Code Not Available
Last Error Code Description Not Available
Last Reset Not Available
Location PCI bus 0, device 2, function 0
Manufacturer Intel Corporation
Microsoft DirectX* Version 11.X
Monochrome No
Number of Colors 4294967296
Number of Video Pages Not Available
PNP Device ID PCI\VEN_8086&DEV_1916&SUBSYS_06DF1028&REV_07\3&11583659&1&10
Power Management Capabilities Not Available
Power Management Supported Not Available
Refresh Rate - Current 59 Hz
Refresh Rate - Maximum 75 Hz
Refresh Rate - Minimum 59 Hz
Resolution 1680 X 1050
Scan Mode Noninterlaced
Service Name igfx
Status OK
Video Architecture VGA
Video Memory Unknown
Video Processor Intel(R) HD Graphics Family
Pre-built systems require customized drivers from the laptop manufacturers. Now, on Windows® 10, it is easier and recommended to install the latest drivers provided with Windows 10 update utility.
I recommend you to make sure you are using the latest BIOS, Chipset and Intel® Management Engine Interface drivers.
Dell drivers in the link below:
http://www.dell.com/support/home/us/en/19/product-support/product/latitude-e5570-laptop/drivers/advanced http://www.dell.com/support/home/us/en/19/product-support/product/latitude-e5570-laptop/drivers/advanced
Mike C
CMurr4
I have put the machine back to all of the latest dell drivers, it is 100% up to date, and it still restarts the video driver daily.
I will need more details about your computer. Please run our tool Intel® System Support Utility and send me the results.
Then, open Intel® HD Graphics control panel>Options & Support>Information Center and click save, keep the .txt in your desktop. Send me the file.
Mike C
I am following your case. Let me know if I can help you with anything else.
Mike C
