22939 Discussions
surface book with LG Monitor 2560x1080 not working
ggige
Hi I have a new surface book
I'm not able to use the LG Ultrawide monitor with 2560x1080 resolution. Windows 10 reports 1920x1080 (recommended).
I downloaded your driver and this is the info from Intel Graphics Control Panel:
Can you help me to solve this issue?
Intel(R) HD Graphics 520
Report Date: Friday, May 13, 2016
Report Time [hh:mm:ss]: 10:08:33 PM
Driver Version: 20.19.15.4444
Operating System: Windows* 10 Enterprise (10.0.10586)
Default Language: English (United States)
Physical Memory: 16307 MB
Vendor ID: 8086
Device ID: 1916
Device Revision: 07
Graphics Output Protocol (GOP) Version: 9.0.1042
Current Resolution: 3000 x 2000
Processor: Intel(R) Core(TM) i7-6600U CPU @ 2.60GHz
Processor Speed: 2808 MHz
Processor Graphics in Use: Intel(R) HD Graphics 520
Shader Version: 5.1
OpenGL* Version: 4.4
OpenCL* Version: 2.0
* Microsoft DirectX* *
Runtime Version: 12.0
Hardware-Supported Version: 12.0
* Devices connected to the Graphics Accelerator *
Active Displays: 2
* Built-in Display *
Display Type: Digital
DDC2 Protocol: Supported
Gamma: 2.2
Connector Type: Embedded DisplayPort
Device Type: Built-in Display
Maximum Image Size
Horizontal Size: 11.42 inches
Vertical Size: 7.48 inches
Supported Modes
3000 x 2000 (60p Hz)
Raw EDID:
00 FF FF FF FF FF FF 00 34 A9 A2 96 00 11 21 44
FF 19 01 04 A5 1D 13 78 03 EE 91 A3 54 4C 99 26
0F 50 54 00 00 00 01 01 01 01 01 01 01 01 01 01
01 01 01 01 01 01 80 A2 B8 68 B1 D0 40 70 08 08
88 00 1D BE 10 00 00 1E 00 00 00 FD 00 2E 3C 5E
7C 2A 01 0A 20 20 20 20 20 20 00 00 00 FC 00 56
56 58 31 34 50 30 34 38 4D 30 30 0A 00 00 00 10
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 68
* Digital Television *
Gamma: 2.2
Connector Type: DisplayPort
Device Type: Digital Television
Maximum Image Size
Horizontal Size: 31.5 inches
Vertical Size: 13.39 inches
Supported Modes
640 x 480 (60p Hz)
640 x 480 (75p Hz)
720 x 400 (70p Hz)
720 x 480 (60p Hz)
720 x 576 (50p Hz)
800 x 600 (60p Hz)
800 x 600 (75p Hz)
1024 x 768 (60p Hz)
1024 x 768 (75p Hz)
1152 x 864 (75p Hz)
1152 x 870 (75p Hz)
1280 x 720 (60p Hz)
1280 x 720 (50p Hz)
1280 x 1024 (75p Hz)
1280 x 1024 (60p Hz)
1600 x 900 (60p Hz)
1680 x 1050 (60p Hz)
1920 x 1080 (50p Hz)
1920 x 1080 (30p Hz)
1920 x 1080 (50i Hz)
1920 x 1080 (60i Hz)
1920 x 1080 (60p Hz)
2560 x 1080 (60p Hz)
Power Management Support
Standby Mode: Supported
Suspend Mode: Supported
Active Off Mode: Supported
Raw EDID:
00 FF FF FF FF FF FF 00 1E 6D F1 59 82 A8 03 00
0C 19 01 03 80 50 22 78 EA CA 95 A6 55 4E A1 26
0F 50 54 A5 4B 80 71 4F 81 80 81 C0 A9 C0 B3 00
01 01 01 01 01 01 7E 48 00 E0 A0 38 1F 40 40 40
3A 00 1E 4E 31 00 00 18 02 3A 80 18 71 38 2D 40
58 2C 45 00 1E 4E 31 00 00 1E 00 00 00 FC 00 4C
47 20 55 4C 54 52 41 57 49 44 45 0A 00 00 00 FD
00 38 4B 1E 5A 18 00 0A 20 20 20 20 20 20 01 D2
02 03 1D F1 4A 90 04 03 22 14 12 05 1F 01 13 23
09 07 07 83 01 00 00 65 03 0C 00 10 00 02 3A 80
18 71 38 2D 40 58 2C 45 00 56 51 21 00 00 1E 01
1D 80 18 71 1C 16 20 58 2C 25 00 56 51 21 00 00
9E 01 1D 00 72 51 D0 1E 20 6E 28 55 00 56 51 21
00 00 1E 8C 0A D0 8A 20 E0 2D 10 10 3E 96 00 56
51 21 00 00 18 00 00 00 FF 00 35 31 32 4E 54 59
54 37 31 37 34 36 0A 00 00 00 00 00 00 00 00 7F
* Other names and brands are the property of their respective owners.
MHick6
Gigetto, I have the same issue and have been reading around. I just read this which seems to be we need to get the surface dock to make it work or MDP-DP cable as HDMI wont do it.
Good luck, I am off to buy a cable now
https://www.reddit.com/r/Surface/comments/417ms0/trouble_with_the_surface_pro_4_and_an_lg/ Trouble with the Surface Pro 4 and an LG Ultrawide monitor ? Cable or driver issue ? : Surface
http://answers.microsoft.com/en-us/surface/forum/surfbook-surfdrivers/cannot-use-ultra-wide-monitor-with-surface-book/1f1af47b-8aad-4065-ad91-d83595f7972d?auth=1 Cannot use ultra wide monitor with surface book - Microsoft Community
MHick6
I purchased a Belkin Mini Display Port to HDMI adapter rated at 4K ($30 AUD), and have a HMDI cable straight into monitor......and it works! Finally!
Here's the catch, the Belkin MDP plug is thicker than the Surface Book so you need to prop it up or find a thinner plug.
Hi gigetto,
In regards to your issue, it is recommended to use the drivers provided with your pc manufacturer. They customized our drivers.
Go to device manager, uninstall and delete the current graphics driver then, restart the system and run Windows® 10 update.
Mike C
Hi gigetto,
I am following your case. Let me know if I can help you with anything else.
Mike C
