22655 Diskussionen
Intel NUC x15 UHD graphics
Zhangirhan
Einsteiger
3.142Aufrufe
Intel UHD graphics' default clock, memory and boost doesn't match actually GPU  memory, clock and boost. This may cause low battery life time. Approximateley 1 min of browsing takes 1 percent of battery in eco mode. How may I get default specs for UHD?
8 Antworten
Stefan3D
Geehrter Beitragender II
3.118Aufrufe
The boost value is quite far out of range.
Looks like an application issue as discussed here:
https://www.techpowerup.com/forums/threads/gpu-z-2-13-intel-hd-620-wrong-gpu-clock-detected.248573/
Zhangirhan
Einsteiger
3.107Aufrufe
Not really that case, it is not misreading like in case you mentonied. This 2 lines should match even if it is misreading of a sensors
Alberto_R_Intel
Mitarbeiter
3.057Aufrufe
Zhangirhan, Thank you for posting in the Intel® Communities Support.
In order for us to provide the most accurate assistance on this topic, first, we just wanted to confirm a few details about your system:
What is the model of the Intel® processor?
What is the model of the motherboard?
If this is a laptop, what is the model of it?
Were the Intel® UHD graphics default values matching the GPU values on GPU-Z before?
If yes, when did the issue start?
Did you make any recent hardware/software changes that might cause this issue?
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows-?product=91600
Albert R.
Zhangirhan
Einsteiger
3.048Aufrufe
Hi, it is laptop NUC x15 with I7 11800hq. Just bought it. battery runs out fast, so i sterted cheching system. It is my home laptop.
Attached ssu and Intel Processor Diagnostic Tool log.
Alberto_R_Intel
Mitarbeiter
3.029Aufrufe
Zhangirhan, Thank you very much for providing that information and the reports.
It is great to see that the processor passed the Intel® Processor Diagnostic Tool test because that will let us rule out a possible hardware problem with the unit.
We will do further research on this matter, as soon as I get any updates I will post all the details on this thread.
Albert R.
Ronny_G_Intel
2.988Aufrufe
Hi @Zhangirhan,
I checked with the NUC engineering team and as mentioned by @Stefan3D this is an application issue.
I would recommend addressing this issue with TechPowerUp* https://www.techpowerup.com/gpuz/
Ronny G
Zhangirhan
Einsteiger
2.968Aufrufe
Hello. It seems problem wasin Windows 11 or its drivers. Now I have installed windows 10 and intel gpu clocks are ok. GPU-Z app version the same
Ronny_G_Intel
2.949Aufrufe
Hi @Zhangirhan,
Thanks for the update, I will report this back to the NUC Product Team, perhaps we can work this out internally but can't really promise anything at this point since this issue is not with the NUC.
I will close the internal case we created for your report, feel free to reopen it by posting new comments if you need anything else.
Ronny G
Antworten
