공지
22755 토론
Intel Performance Telemetry giving incorrect VRAM read and write bandwidth
Bill_da_da
새로운 기여자 I
5,787 조회수
I just find out after I updated to driver 5081 WHQL and enabled my integrated graphics in BIOS, the numbers in the intel performance telemetry(comes with arc control) is showing wrong number(seems to be capped at 10000 MB/S but I think it is somewhat working below that like idling) in the overlay.
Bill Ge
0 포인트
17 응답
Andres_Intel
직원
5,733 조회수
Hello Bill_da_da,
Thank you for posting on the Intel®️ communities. I will be happy to help you. Since you are having issues with the VRAM read and write bandwidth with the Telemetry Overlay of Intel® Arc™ Control , please follow the steps below and keep me informed of the results:
  1. Uninstall Intel® Arc™ Control
    1. Press the Windows key.
    2. Click on settings.
    3. Select Apps and then select Apps & features.
    4. Search for Intel® Arc™ Control software.
    5. Click on it and select the option to uninstall.
  2. Install graphics driver 31.0.101.5081. The installer will install the Intel Graphics driver and Intel Arc Control components.
Andres P.
0 포인트
Bill_da_da
새로운 기여자 I
5,713 조회수
Hi Andres,
I have uninstalled the arc control and the driver(DDU) and installed them again. It seems like the problem persists.
Bill Ge
0 포인트
Andres_Intel
직원
5,666 조회수
Hello Bill_da_da,
Thank you for completing the steps.
I will start with an investigation to provide you with the next steps, as soon as possible.
Andres P.
0 포인트
Andres_Intel
직원
5,661 조회수
Hello Bill_da_da,
Thank you for your time.
I am still working on the investigation, but just to clarify, if you disable the integrated graphics card in BIOS, does it work properly?
Andres P.
0 포인트
Bill_da_da
새로운 기여자 I
5,641 조회수
Hi Andres,
I think the problem occurs when the integrated graphics is on and off after I test it. It does not matter whether if integrated graphics is on or not.
Bill Ge
0 포인트
Andres_Intel
직원
5,614 조회수
Hello Bill_da_da,
Thank you for your clarification.
I will continue with the investigation, and as soon as I have the next steps I will let you know.
Andres P.
0 포인트
Andres_Intel
직원
5,560 조회수
Hello GSage,
Thank you for your patience.
We still working on the investigation, and now we will start with the issue reproduction, as soon as I have the results I will let you know.
Andres P.
0 포인트
Jean_Intel
직원
5,504 조회수
Hello Bill_da_da,
We would like to let you know that we have tried to replicate the issue you described internally; however, we were not able to reproduce the problem. When we enabled both GPUs (integrated and discrete) in the BIOS, the Arc Control telemetry never reached the 10000 MB/S mark, the information for VRAM read and write worked as expected on our end.
Based on this, we would like to recommend you install the latest graphics driver, 31.0.101.5084 after you run the DDU to eliminate all the previous drivers and residues.
Best regards
Jean O.
0 포인트
Bill_da_da
새로운 기여자 I
5,496 조회수
Hi Jean,
The reading is capped at 10000MB/s not stayed at 10000MB/s. I think you will need to fire up some workload to actually use VRAM and you can see the issue. BTW, I have just tried DDU and reinstall and the problem persists.
Bill Ge
0 포인트
Bill_da_da
새로운 기여자 I
5,495 조회수
The screenshot after reinstalling and running Dead Space in the back:
It is building shader so it is CPU intensive but the VRAM usage is also above 10000MB/s. If it stays at idle, the VRAM usage will be less than 10000MB/s and it will just be fine.
0 포인트
Jean_Intel
직원
5,461 조회수
Hello Bill_da_da,
We understand that you reported a cap of 10000 MB/s on the reading. Let us resume our research on this matter, and we will post back as soon as we have more information.
Best regards
Jean O.
0 포인트
Andres_Intel
직원
5,345 조회수
Hello GSage,
We still working on the investigation and now we will strat with the issue replication, as soon as I have the results I will let you know.
Andres P.
0 포인트
Andres_Intel
직원
5,284 조회수
Hello GSage,
We have been working on the replication and we hope to have the results soon.
Andres P.
0 포인트
Andres_Intel
직원
5,116 조회수
Hello GSage,
Thank you for your time and patience.
We still working on the replication and we will have the results soon, as soon as I have them I will let you know.
Andres P.
0 포인트
Bill_da_da
새로운 기여자 I
4,680 조회수
Hi Andres,
It's been a couple of months. Any updates on the issue?
Bill Ge
0 포인트
Damien1
초급자
4,790 조회수
Hey there !
I have been testing my A770 LE predominantly for high refresh rate/competitive games and have run into this exact issue on the latest driver (101.5333), on windows 10.
Playing overwatch 2 always showed the "VRAM Read Bandwidth" being capped at 10,000mb/s in the overlay.
I tried the same test using driver 101.4091 and found that the version of arc control bundled with this driver did not have this problem, the bandwidth readings were between 25,000 and 30,000 during gameplay, and the graph scaling appropriately.
I must note that I am using a core i5 10400f and I forced the arc control software to install (I think it is technically only supported with 11th gen).
**Edited: I just made a new test using a GTX 970, and it turns out there must be something wrong elsewhere with my configuration as I ran into the same problem where my frame rate does not go beyond a point. Ignore what I wrote below as it is quite irrelevant. However if somebody knows about this kind of behaviour I would love to hear it!**
With that said, I hope to see some more driver optimization on DX11 titles like this one before DX12 becomes the focus. With both drivers, neither the gpu or cpu usage got to 100% in my testing as long as shaders aren't being compiled: This meant that there is performance left on the table when it comes to competitive titles.
When using the older 101.4091 driver, here is what I found playing overwatch 2 at the lowest graphical preset:
120 - 160 fps
35-60% render activity
%45 CPU activity
The hardest working CPU thread gets to 80% at the highest according to MSI afterburner.
The newer 101.5333 driver performed slightly better, but still could not utilize system resources.
0 포인트
RonaldM_Intel
중재자
1,297 조회수
Hi everyone,
This issue should be fixed with latest driver 32.0.101.6732 and newer.
Please give it a shot and let us know your feedback.
Ronald M.
0 포인트
응답
