Intel Q45/ Q43 Display adapter:
Running WIN8.1, Pro; other specs of the computer: Intel Quad core 2, Quad CPU, Q9550 @2.83Ghz, 8gb ram, 64 bit.
I have a new Dell U2415 displayport monitor with 1.2 capability. I wish to daisy chain from the Dell to an Acer G226HQL monitor.
Is the graphics adapter certified to allow for this daisy chain setup? That is, Can graphics adapter support DPMST/ HBR2 (High Bit rate)
I can not seem to get a picture on the Acer, daisy chaining to the Dell and wonder if it is something I may have done incorrectly.
Can the issue be the ACER?
Please advise.
連結已複製
Thank you. Looking forward to reading the results of your research.
"Intel Quad core 2, Quad CPU, Q9550 @2.83Ghz, 8gb ram, 64 bit."
I suspect this system does not support my Daisy chain needs.
Here is the DX diagnostic info on this system..
Thank you for your help.
Please advise..
RJL24
Hello RJL24,
Thank you for sharing this information. Based on the report you provided, this processor does not have onboard graphics so the configuration you are attempting will depend on the motherboard limitations o capabilities.
My recommendation at this point is to confirm with the motherboard manufacturer if it can support DPMST/ HBR2.
@ RJL24,
Your system is made by HP, the driver downloads for the system is here: http://h20564.www2.hp.com/hpsc/swd/public/readIndex?sp4ts.oid=4065873&swLangOid=8&swEnvOid=4060 http://h20564.www2.hp.com/hpsc/swd/public/readIndex?sp4ts.oid=4065873&swLangOid=8&swEnvOid=4060
However, HP does not list Windows 8.1 as a supported OS for your system. Additionally, HP list 5 possible graphics options for your system as follows:
That said, if your system did have the Intel Q43/Q45 graphics, it would not support daisy chaining of displays or have updated Intel graphics driver avail for it. Intel did not provide graphics drivers for the Q43 /Q45 graphics on Windows 8/8.1. Inbox drivers provided by Microsoft are the only available drivers for this combination.
Robert
Please advise..
RJL24
Hello RJL24,
@ RJL24,
Robert
