22850 Discussions
Intel UHD 770 2560x1140 dual monitor setup
Momin
Hi
I recently purchased a dell OptiPlex 3000 with intel UHD 770 graphics I have setup a dual monitor setup with Samsung displays LS24A600UCMXUE up to 2560x1140 @75Hz refresh rate.
I have connected one monitor by display port to display port and it works fine and resolution and everything is fine
But the other monitor connected via HDMI to HDMI (because I have only one Display port in CPU) is not showing full resolution and is little blurred.
can I use splitter on the display port and connect both monitors via display port instead of HDMI?
MUC
Honored Contributor I
Your device has a DisplayPort connection version 1.2 with HBR2 signaling.
Please try as described in the monitor manual:
AlHill
Sure, go ahead and use a splitter.   HOWEVER... You will only be duplicating what is on one monitor to the other.  You will not be able to extend your displays.
A splitter is not what you want.
Momin
no i want to use my setup as a extended display so can i use HDMI to display port cable ? if not then what is the solution to have full resolution on my second monitor?
MUC
Momin
thank you so much it worked!!!
