22683 Discusiones
Intel UHD Graphic 770 , but 10 bit not available
Chris-K
Novato
18.186 Vistas
I have the Alder Lake i7-12700K on a Gigabyte Z690 Gaming X DDR4 Mainboard.
Newest drivers on Windows 11.
Connected via HDMI to a LG 31MU97Z-B Monitor.
The monitor supports 4K and 10 bit.
The Intel Graphics Command Center only shows me 8 bit.
But not 10 bit.
I tried to use another cable, but the same problem.
Is there any idea?
Thanks!
0 kudos
16 Respuestas
DeividA_Intel
Empleados
18.153 Vistas
Hello Chris-K,
1. Run the Intel® System Support Utility (Intel® SSU) to gather more details about the system.
2. Provide the Report for Intel® Graphics Drivers:
https://www.intel.com/content/www/us/en/support/articles/000005848/graphics.html
3. Were the configurations 10-bit and 4K working before with this computer?
4. Can you take a picture from the Intel® Graphics Command Center (Intel® GCC) where we can see the "bits" settings?
Deivid A.
DeividA_Intel
Empleados
18.128 Vistas
Hello Chris-K,
Were you able to check the previous post and get the information requested? Please let me know if you need more assistance.
Deivid A.
Chris-K
Novato
18.122 Vistas
Hi Deivid,
yes, but I have to upload the report from the SSU. I think I can do it later today or tomorrow.
Than I will answer the questions too.
Thank you!
Chris
Chris-K
Novato
18.112 Vistas
Hello Deivid,
the configuration hasn't worked on this computer before.
Here I wil send you a picture of the Graphics Command Center and the reports.
I hope you can have a look at them to find the problem...
Thank you!
Chris
DeividA_Intel
Empleados
18.105 Vistas
Hello Chris-K,
Before we continue further, I would like you to try the following as a test.
Perform a clean installation of the Intel drivers:
Please let me know if the issue persists.
Deivid A.
Chris-K
Novato
18.099 Vistas
Hello Deivid,
I deleted and reinstalled the newest driver like told in the link.
The problem is the same, no 10 bit...
Best,
Chris
DeividA_Intel
Empleados
18.085 Vistas
Hello Chris-K,
Thanks for all the information provided, with this I will proceed to check this issue internally.
I will post back with any datils or steps as soon as possible.
Deivid A.
DeividA_Intel
Empleados
18.063 Vistas
Hello Chris-K,
Thanks for your patience. Based on the research I would like you to try the following:
1. Check if the monitor has the latest firmware
2. Update the graphics driver to version 30.0.101.1002 (Gigabyte) if it does not work, update it to version 30.0.101.1191.
3. Check for these steps:
  • Enable HDR (High Dynamic Range) and WCG (Wide Color Gamut) in the operating systems for higher color depths by going to Windows > Display settings > Windows HD Color. If the content you're trying to view is 10-bit, switch to Full-Screen mode, and the driver will automatically switch to the higher color depth, given HDR and WCC are enabled.
4. Can you change to format YCbCr mode?
5. Confirm if the TV menu has an option similar to enabling Deep Color or YCbCr.
6. Check the Display Settings > Advanced Display Settings in Windows to confirm if the video mode is enabled by the Display
Deivid A.
Chris-K
Novato
18.049 Vistas
Hello Deivid,
I checked 1, 2, 4 and 5. I think this is okay.
Number 3 is not posible. I have no option to set to HDR.
I read the Windows 11 information about the HDR setting. They said that you will need Display Port 1.4 or HDMI 2.X for HDR.
But my monitor only has DP 1.2 and HDMI 1.X
So my final idea is, that the monitor is the problem here.
I don't understand why, because 10 bit is not the same than HDR.
LG wrote me that the 10 bit is a thing that the driver of the grapic card has to do. But they are not talking about HDR.
Do you know it the graphic driver need HDR enabled to use the 10 bit?
Thank you!
Chris
DeividA_Intel
Empleados
18.042 Vistas
Hello Chris-K,
Thanks for your response. In this case, our drivers are compatible with HDR technology. However, not sure if is needed HDR to be able to enable the 10 bit.
Also, let me know if you were able to perform the steps (except step 3) and what were the results.
Deivid A.
DeividA_Intel
Empleados
18.023 Vistas
Hello Chris-K,
After checking your thread, I would like to know if you need further assistance.
If so, please let me know.
Deivid A.
Chris-K
Novato
18.008 Vistas
Hello Deivid,
the next step is try another monitor.
I will report...
Thank you!
Chris
DeividA_Intel
Empleados
17.997 Vistas
Hello Chris-K,
Thanks for letting me know, I will be waiting for your results.
Deivid A.
DeividA_Intel
Empleados
17.991 Vistas
Hello Chris-K,
Were you able to try a different monitor? Please let me know if you need more assistance.
Deivid A.
DeividA_Intel
Empleados
17.974 Vistas
Hello Chris-K,
I was checking your thread and see that we have not heard back from you.
I’m going to close your post, but if you need further assistance, please do not hesitate in contacting us.
Deivid A.
Chris-K
Novato
17.959 Vistas
Hello Deivid,
at the moment I'm looking what kind of monitor I can buy.
But I will need some more time to look for a good monitor that is not to expensive.
You can close the post for now and I hope I can write later what happend with a new monitor.
Thank you!
Chris
Responder
