23838 Discussions
Intel UHD630 display frequency
skomisko
Hi, sorry to bother you
I've recently bought a new laptop with the Intel core i5 10500H, from what I've found it has the Intel UHD 630 iGPU. I've hooked it up to my old XG2401 which is a 144hz panel with HDMI. I'm unable to set the display to anything more than 120Hz, I'm using a certified premium HDMI cable with a HDMI 1.4 supported on the XG2401.
I updated all the drivers, the driver itself tells me that 144Hz is supported  but doesn't actually let me to set the refresh rate.  Am I missing something or is this completely normal ?
Thank you in advance for your answer.
Have a wonderful day.
n_scott_pearson
All I can say is that, for some reason, the graphics driver is determining the supportable refresh rate and, while it is high enough to support 120Hz, it is not high enough to support 144Hz. This may be the laptop's fault and not your cable, but I would be trying another cable.
Hope this helps,
Alx24
New Contributor II
Typical display EDID with resolution 1920x1080 at 144 Hz contains:
DTD 3: 1920x1080 143.563349 Hz 16:9 166.103 kHz 332.870000 MHz (598 mm x 336 mm)
Hfront 8 Hsync 32 Hback 44 Hpol P
Vfront 63 Vsync 8 Vback 6 Vpol N
http://community.intel.com/t5/Graphics/Intel-UHD-750-doesn-t-display-2k-75Hz-on-external-monitor/m-p/1329167#M102786
"HDMI 1.4 mode, and here the pixel clock is limited to 297MHz. HDMI 1.4 mode, and here the pixel clock is limited to 297MHz"
And
https://www.intel.com/content/www/us/en/support/articles/000037046/graphics.html
"Unable to achieve 144Hz refresh rate using an Intel® Core™ i5-7400 Processor and 144 Hz monitor"
And
https://community.intel.com/t5/Graphics/120hz-limit-on-144hz-monitor-on-intel-uhd-620/m-p/1248737#M93650
How to Connect to a 120+ Hz display | Tom's Hardware Forum (tomshardware.com)
"How to Connect to a 120+ Hz display"
"6.3. How to set a custom resolution"
"6.3.3. Intel:"
( Button "Help")
Intel Community search "144Hz"
https://community.intel.com/t5/Graphics/Intel-hd-620-2k-144hz/m-p/1226047
In may be possible in Custom Resolution in IGCC ( Intel Graphics Control Center ).
https://www.intel.com/content/www/us/en/support/articles/000056144/graphics/legacy-graphics.html
"How to Set Custom Resolutions and Modes in Intel® Graphics Command Center"
Alx24.
