23854 Discussions
Intel adapter flips landscape orientation when enabled
gratyork
Latitude 5520 has two display adapters- intel and nvidia. When the intel adapter is enabled, the pc monitor displays landscape flipped. If the intel adapter is disabled, the monitor goes back to normal. If the pc is connnected to a docking station with its own display adapter, and intel adapter enabled, the monitor is normal, but if the docking station is disconnected from the docking station with the intel adapter enabled, the screen reverts to the flipped orientation.
When disconnected from the docking station and Intel driver enabled, the screen setting for Orientation is grayed out.
All display adapters have had a clean install.
Ideas to fix?
VonM_Intel
Hi, gratyork
Thank you for posting in our Community and for providing such detailed information regarding the issue you're experiencing with your Latitude 5520’s display orientation. I’ve sent an email with further details regarding this matter. Kindly review and respond at your earliest convenience so we can proceed with the appropriate next steps.
Have a nice day!
Von M.
VonM_Intel
Hello, gratyork.
I've responded to your inquiry via email regarding this matter, including the duplicate community thread post. I will now close this thread and continue assisting you through your other active post.
Von M.
