공지
23793 토론
Intel arc a750
AjuL227
초급자
2,499 조회수
I am using i5 10400 cpu and my motherboad is gigabyte h510mh v2 which supports 3.0 pcie having a ram 16gb, also it have resizable bar option i checked
But my question is that this specs can leads any trouble, bottleneck issues with intel. Arc a750 (which i am going to buy)
, can i get good fps in games using, rendering this specs
Please reply
0 포인트
3 응답
VonM_Intel
중재자
2,432 조회수
Hi, AjuL227.
A bottleneck isn’t necessarily caused by the quality or age of components, but rather their performance. Bottlenecks aren’t unique to high-end systems either; balance is equally important in systems with more entry-level hardware. Your setup appears to be well-balanced for gaming and rendering tasks. The i5 10400 CPU, paired with the Gigabyte H510MH V2 motherboard and 16GB of RAM, should provide a solid foundation. Additionally, the support for PCIe 3.0 and resizable bar option can enhance performance. While bottleneck issues can arise with hardware combinations, your configuration seems compatible with the Intel Arc A750 GPU. You should expect good FPS in games and smooth rendering performance with this setup. However, for precise performance expectations, it's recommended to check benchmarks or reviews specific to your intended usage scenarios.
You may check the following articles below:
I hope this helps.
Von M.
0 포인트
NormanS_Intel
중재자
2,375 조회수
Hello AjuL227,
I wanted to check if you had the chance to review the information we posted. Please let me know at your earliest convenience so that we can determine the best course of action to resolve this matter.
Norman S.
0 포인트
NormanS_Intel
중재자
2,321 조회수
Hello AjuL227,
Norman S.
0 포인트
응답
