連結已複製
Hello Alpi,
Thank you for posting in the community. Could you please try downloading the 7-Zip application and use it to extract the executable file of the Intel Arc Graphics driver? After extraction, you should find a folder named "Resources." Inside that folder, there will be another folder called "Extra." Navigate to the "Extras" folder, and you will see an executable file for the Intel Graphics Software. Please try installing it on your system and let me know the results.
By the way can you tell me if what GPU you are using on your system?
Dhanniel M.
I only found uninstall.exe in this file. Also, the application appears in the Windows control panel, in the uninstall program section, but I cannot find it as an application
Why ı cannot click intel graphics software button during installing?
Hello Alpi,
It seems there might have been some misunderstanding. I wanted to clarify the process for the driver you downloaded from the Intel website (gfx_win_101.6559).
First, you'll need to extract this executable file using the 7-zip application. Once extracted, you should find a folder named "Resources." Inside this folder, there will be another folder called "Extra." Navigate to the "Extra" folder, where you'll find an executable file for the Intel Graphics Software.
Before installing the Intel Graphics Software, please uninstall any existing version from your Control Panel. After doing that install the IGS alone only.
Dhanniel M.
Hello Alpi,
Have you had a chance to review the information I shared earlier? It clarifies your previous response in this thread. Could you update me on the current situation?
Dhanniel M.
Hello Alpi,
That's wonderful news! I'm glad to hear that the issue has been resolved. Could you please share the steps you took to solve it? Additionally, did my recommendation assist in any way?
Dhanniel M.
Hello Alpi,
I hope this message finds you well. I wanted to check if you've had a chance to review my previous reply. Could you please confirm if the issue has been resolved so we can close this inquiry? Your prompt response would be greatly appreciated.
Dhanniel M.
Hello Alpi,
Since I haven't heard back from you, I will close this inquiry now. If you need further assistance, please submit a new question, as this thread will no longer be monitored.
Moreover, you can check on this article for further information: Intel® Graphics Software Isn’t Being Installed with Driver
Dhanniel M.
