23586 讨论
IntelHDGraphics630 with MSI GeForce GT 710
ISilv3
初学者
4,233 次查看
I've just bought this computer https://www.amazon.co.uk/gp/product/B06Y5ZQKX2?ref_=pe_2105081_77703951_E_Asin_Title https://www.amazon.co.uk/gp/product/B06Y5ZQKX2?ref_=pe_2105081_77703951_E_Asin_Title with an Intel graphics cards included.
Because I want 4 monitors, I've also bought this graphics card and installed in my machine https://www.amazon.co.uk/dp/B01AY78MLM/ref=pe_3187911_189395841_TE_3p_dp_1 MSI GeForce GT 710 Passive Silent 2 GB Graphics Card - Black: Amazon.co.uk: Computers & Accessories
Problem is on my display adapters in Device Manager only the NVIDIA shows up (even if I select hidden devices as well). No monitor gets detected by the Intel graphics card.
I was trying to delete and reinstall both drivers, but after deleting both and restarting the PC, NVIDIA just kind of automatically installed itself and the Intel looks to be gone for good.
Any help on this?
Cheers
0 项奖励
3 回复数
AlHill
超级用户
3,112 次查看
Does the Zoostorm bios support both the onboard (intel) and add-on (nvidia) AT THE SAME TIME?
Typically, insertion of an add-on card disables the onboard graphics.
Check your bios, and ask the system manufacturer (if you can contact Zoostorm) about this.
To test, remove the add-on card and see if the onboard graphics work.
Stop deleting drivers until you know what is really happening.
Doc
ISilv3
初学者
3,112 次查看
I found this on their Q&A:
Can I install my own graphics cards?
Is it technically possible to install a graphics card and which graphics cards will be compatable. I want to do a few things which I think I will need a graohics card for
Hi Jaruip, Thanks for contacting us. Yes it is possible to install a discreet graphics card. The Evolve system can support up to an Nvidia GT 1030 or AMD Radeon RX 550. Regards Nathan
By: Zoostorm
Does this mean my graphics card is not supported?
0 项奖励
AlHill
超级用户
3,112 次查看
Intel did not make your graphics card. You will have to ask your system manufacturer about your nvidia card.
Your intel graphics are not a "card". They are graphics that are built into your processor. This is different than an add-on graphics card.
Just ask zoostorm.
Doc
0 项奖励
回复
