23586 Discussions
Iris Xe and AWS Workspaces
mikabrown
Have an issue with the AWS Workspaces client on my HP laptop with 11th Gen i7-1165G7 / Iris Xe.  In the end it feels like a driver issue...
The login screen for the app does not show my input, but if I blindly enter username/pw, it will log in.  Then the main desktop screen is just black.  Occasionally a portion of the screen will become visible if I move things around / minimize / maximize.
I found similar issues for 11th Gen Iris Xe reported with Citrix and Logos apps.  Suggested from Logos was to disable acceleration for WPF applications via registry: HKCU\SOFTWARE\Microsoft\Avalon.Graphics\DisableHWAcceleration : 1
This immediately solved the problem, but disabling acceleration doesn't seem like a long term fix.
Tried with Intel driver version up to this weeks  27.20.100.9126.
Tried with Workspaces version up to current 3.1.2.
So is this a know issue with the Intel drivers and the 11th Gen Iris Xe? Or more with the app?
Thanks!
Mika
Gabriela_Intel
Update: Production driver 30.0.100.9684 is now up in Download Center! Check it out.
Bamba
As asked above, did the beta version released on 6/8 fix this issue?
Also. When will the official version be released?
We are in great trouble.
RadioEngineer
Greetings,
Good news, I finally had a moment to set up a "sand box" environment to test the 30.0.100.9667 June 8th beta release.  My testing confirmed this beta resolves the WPF related bugs described in this thread.  I also received confirmation from three other users of the same WPF based software that it resolved there issue as well.  With a few more days of testing we will considering using the beta in the production environment, but of course would prefer a production release.
We had switched to AMD based laptops to avoid this issue but the Intel products have some battery performance advantages and were easier to source so we plan to move back.
Best,
Ted
Len99
I've just loaded the XE Graphics Driver ver: 30.0.100.9684 and now two of my applications display full screen without a taskbar.
The first is the WhatsApp desktop app and the second is the MS Search (keyboard shortcut: Win+S).
I am using the latest version of Windows 10.
Noise79
I'm having the same issue. Could you please provide a link for the driver update and confirm it fixes the issue with whatsapp qr code?
Len99
My solution was to download latest version of the Intel Graphics Driver (https://www.intel.com/content/www/us/en/download/19344/30579/intel-graphics-windows-dch-drivers.html)
then Install using the standard Windows process via Device Manager; Display Adaptors.
NOTE: When I used Intel Support Assistant to update it uninstalled my Realtek sound drivers and put me in an endless loop! Reinstalling sound then caused the Graphic driver to be rolled back. From memory I believe this happened because Windows Update intervened and overwrote the Graphic driver.
Since then 30.0.100.9864 has remained static and WhatsApp QR code worked fine the last time I needed it.
I hope this helps you too.
Len
Bamba
As you can see in the comment above, did this bug have been fixed in the beta version released on 6/8? Also, we are waiting for the official release, not the beta version. When are you planning this?
mikabrown
Glad to here this is being addressed.  Should we be concerned that it's now July and no production driver release?  Or is it being held up because the fix caused and issue in a game 😉
Bamba
nls-
What's taking so long? It's been almost one month since the suggested release date and everything is working fine in the latest beta version. I've installed that one but it keeps getting overwritten every so often by Windows which sees the retail driver as being newer. No big deal for me since I just reinstall the beta driver, but I assume there's a lot of professional customers waiting for this to get solved who aren't allowed to install a beta driver.
n_scott_pearson
These things take time. There are a lot of hardware scenarios and a lot of software scenarios that all have to be validated before a Beta release is committed. Depending upon the changes being included, this can sometimes take months to finish. My advice? Patience, Grasshopper.
Aikurna
Hi to all young and old grasshoppers. My computer is working fine since I installed driver 27.20.100.9616 from Intel downloadcenter. I didn't try the newer beta versions. With this I can stay patient.
Gabriela_Intel
Hey everyone! I see that some of you are waiting on the next production release. Good news is that we're aiming to release a production driver with the fix to downloadcenter.intel.com within the next two weeks. Stay tuned!
Gabriela_Intel
