hello,
a quite old game i just bought on steam, UFO: Aftershock, seems to have video compatibility issues and fails to load at start.
Is there any way to address the issue?
Hello peemster,
Thank you for posting on the Intel® communities. I want to understand what happened just as much as you do.
To have a better view of this issue, I would like to gather the following:
1. Run the Intel® System Support Utility (Intel® SSU) to gather more details about the system.
- Download the Intel® SSU and save the application on your computer: https://www.intel.com/content/www/us/en/download/18377/intel-system-support-utility-for-windows.html
- Open the application, check the "Everything" checkbox, and click "Scan" to see the system and device information. The Intel® SSU defaults to the "Summary View" on the output screen following the scan. Click the menu where it says "Summary" to change to "Detailed View".
- To save your scan, click Next and click Save.
2. Do you have any issues with other games?
Deivid A.
hi,
my system details are the following:
Processor: Intel(R) Core(TM) i5-1035G4 CPU @ 1.10GHz
Processor Speed: 1498 MHz
GFX Driver Name: Intel® Iris® Plus Graphics
Shader Version: 5.1
OpenCL* Version: 3.0
* Microsoft DirectX* *
Runtime Version: 12
Hardware-Supported Version: 12
Vendor ID: 8086
Device ID: 8A5A
Device Revision: 07
GFX Driver Version: 27.20.100.9621
Dedicated RAM: 128 MB
Shared RAM: 4 GB
Max Supported Displays: 3
GFX Vulcan: 1.2.175
GFX GOP: 14.0.1043
i never experienced fatal crashes in games, they might of course run slow, but never for old games like the one we are discussing.
thanks a alot.
Hello peemster,
Thanks for your response. I checked a few forums and this seems to be a compatibility issue with the Intel-integrated graphics (as you mentioned), bear in mind that the game developer chooses which components will be compatible with their games.
I recommend you to test with the latest Intel driver and if the issue persists, get in contact with the game developer for further information.
Please keep in mind that this thread will no longer be monitored by Intel.
Deivid A.
