22745 Discussions
Issue with 11th gen and midi controllers, failure in sound
FranJ
Hi there,
I looked for a solution in the blog but didn´t found it. Same issue than other users:
https://community.intel.com/t5/Processors/Issue-with-11th-gen-i5-and-midi-controllers/td-p/1267601
https://community.intel.com/t5/Processors/Problem-with-midi-controller-and-intel-i7-11th-gen/m-p/1282707
I have updated all the drivers and the bios from hp support assistant. And drivers from Intel too, but still have the problems with many drops and poor quality in sound. Using SeratoDj Pro and a MCX8000 from Denon. But reading in the net this is not the problem, people with other programs or controllers have the same issues.
Is there any solution ¿?
Thanks in advance
FranJ
Details of my PC
HP Pavilion x360 Convertible 14-dy0xxx
11th Gen Intel(R) Core(TM) i5-1135G7 @ 2.40GHz 2.42 GHz
8 GB RAM
Device Connected to the PC: Denon MCX8000, by a typeB USB cable
Attached a System Support archive.
FranJ
Any moderator or someone from Intel checking this problem¿¿?¿
Steven_Intel
Hello FranJ,
In order to better assist you, please provide the following information:
  • Provide a video or audio of the issue you are having.
  • Were you able to get good quality sound and performance before? If so, was there any change (e.g. hardware upgrade or software/OS updates) before the issue started?
Steven G.
FranJ
Hi again!
Attached an audio file of the poor quality of sound.
It doesn´t happens always. Some times its this failure and other times is the completely lost of sound during minutes. It seems like a fail in connection between the pc and the controler. In the device manager, in usb controllers, sometimes detects the controller and other times it show a failure. I´ve proved the two usb ports of the pc, and with another cable with the same result.
It´s a new pc. I bougth it in February and i have updated the intel drivers and the HP drivers. Today I´ve restored it to factory configuration,  but the issue don´t dissapear...
Steven_Intel
Thank you for your response.
We are currently working on this issue. As soon as I have an update, I will let you know.
Please feel free to reply if you have any concerns.
Steven G.
FranJ
Any update?
Steven_Intel
Hello FranJ,
After working on this issue and taking into consideration the device is connected via USB, the drivers that handle the audio are USB. This is not a graphics issue and it should be reported to Microsoft as the operating system provides USB drivers for the chipset components and Microsoft can debug.
If they need Intel's input, they can work directly with us.
Please contact Microsoft support for further assistance (https://support.microsoft.com/)
Steven G.
