Ankündigungen
22748 Diskussionen
Issue with Graphics Driver Update Causing Screen Artifacts
lalaki
Anfänger
7.510Aufrufe
Dear Everyone,
I would like to report an issue I encountered after updating my graphics driver. Following the update, I have been experiencing screen artifacts.
I would like to know what happened in this situation. Will this issue be resolved?
Device information
CPU: i5 11400
Driver Version: 32.0.101.5971
1 Lösung
AlfredoS_Intel
6.938Aufrufe
Hi Lalaki,
Thank you for providing that information.
We will continue checking this and the information that provided is invaluable to us.
Please allow us some time to check on this. We hope for your understanding regarding this
Alfred S
Intel® Customer Support
Lösung in ursprünglichem Beitrag anzeigen
15 Antworten
AlfredoS_Intel
7.401Aufrufe
Hi Lalaki,
Please allow me to ask the following questions, so I can answer your question and provide you viable suggestions:
1. It would really help us if we can get more information about your system. Please download and run our Intel® System Support Utility from this page. To run it, please press "Scan". After the scan is finished, click next and there will be a save button, giving you an option to save the logs to a text file, please do so and attach the file on your reply. You can refer to How to get the Intel® System Support Utility Logs on Windows* for instructions.
2. Did you try rolling back the driver? Did it fix the issue, if you did try it?
Awaiting your response.
Alfred S
lalaki
Anfänger
7.350Aufrufe
I would like to know what happened, if possible. Thank you for your help.
AlfredoS_Intel
7.359Aufrufe
Hi Lalaki,
I wanted to check if you had the chance to read the questions that we posted. Please let me know at your earliest convenience so that we can determine the best course of action to resolve this matter.
Alfred S
AlfredoS_Intel
7.296Aufrufe
Hi Lalaki,
Thank you for the logs.
After analyzing the logs, here are our suggestions:
1. Please try to update to the latest graphics driver, 32.0.101.5989. Check if you still have the problem.
2. Do you have Intel Graphics Command Center or Intel ARC Control installed?
3. Does the issue happen only when your browsing the Internet?
4. Your CPU has a dual GPU setup. Have you also tried updating your Nvidia discrete laptop graphics?
Alfred S
lalaki
Anfänger
7.290Aufrufe
I tried this version and it works fine!
 Intel® Arc™ Pro Graphics - Windows* 31.0.101.5525
I only installed the driver itself.
I don't have Nvidia discrete graphics enabled, and I've confirmed it’s unrelated.
The recently released version still does not work properly under any circumstances.
AlfredoS_Intel
7.233Aufrufe
Hi Lalaki,
Thank you for considering our suggestions so far.
Based on your post, it seems that it is working on an older driver. There are some settings in the Intel Graphics Command Center that could potentially cause the issue that you are experiencing. Do you have one installed or just the Intel ARC Control program?
Alfred S
lalaki
Anfänger
7.212Aufrufe
Yes, no matter which recent version I update to, it never works properly.
I always perform a clean installation, including using DDU for uninstallation.
How to Use the Display Driver Uninstaller (DDU) to Uninstall an... (intel.com)
AlfredoS_Intel
7.170Aufrufe
Hi Lalaki,
Thank you providing those information.
We will get back to you as soon as we have updates.
Alfred S
AlfredoS_Intel
7.168Aufrufe
Hi Lalaki,
I already began the initial phase of investigating your concern.
To further our investigation, kindly provide the following:
1. Monitor model
2. How is the monitor connected to your system? (HDMI, Display Port, etc.)
3. If possible, kindly provide the model of the video cable that you are using.
Looking forward to your post.
Alfred S
lalaki
Anfänger
7.095Aufrufe
It is a notebook(CLEVO N960KR); it does not require a video cable.😋
AlfredoS_Intel
7.047Aufrufe
Hi Ay2,
Thank you for your response.
Much obliged for pointing out that this is a notebook. The reason why I asked for the display model is because it is using a desktop CPU.
Since you have brought up that this is a notebook, sometimes a BIOS update could fix the issue that you are having as your system’s BIOS needs to be in sync with the changes on the latest driver. Can you confirm if you are using the latest BIOS for your notebook?
I will wait for your confirmation.
Alfred S
lalaki
Anfänger
7.014Aufrufe
Yes, it has always stayed up to date, including the microcode.
The last version I know that works properly is this one
Intel® Graphics Driver 32.0.101.5768
Every version newer than it has issues without exception.
AlfredoS_Intel
6.939Aufrufe
Hi Lalaki,
Alfred S
AlfredoS_Intel
6.533Aufrufe
Hi Lalaki,
Thank you for waiting for our update.
We are not able to duplicate the issue with all the latest driver versions of UHD 730, it could be an Original Equipment Manufacturer issue, meaning our latest graphics is incompatible with your system. Please reach out to your system manufacturer to get a fix or install the latest driver that they officially released on their site.
We hope for your understanding on our findings, that we validated through long hours of simulation.
Alfred S
Susted
Einsteiger
6.408Aufrufe
Hello i have a problem that occured newly when i wanted to Play Red dead redemption 2 i saw that shadows looks weird like pixelated or something  i also tried other Shadow quality seetings but nothing changed ,  in other game like Minecraft   problem also occurs
with shaders or without , also i wanted to mention that shaders with ray traycing and some games that support RT for example Resident evil 7  when it is enabled like red/green  spots apper and they flicker or dissaper as soon as i turn my game character fov on the spot
i also Disabled Ovverdrive option in my Monitor from Extreme to OFF but also nothing changed
i updated my Gpu Driver to this one [ Image screenshot] but it didnt helped
Could it be Faulty gpu then? Should i replace it ? i have ARC A770 16GB ASROCK for around 10 Months and i didnt see something like that before so thats why im asking.
Antworten
