22949 Discussions
Laptop display flashing issues after updating graphics drivers
Kukisiki6665
A laptop from ACER with an integrated Intel Graphics 630 graphics card. The problem is that after updating the graphical solution, namely, auto-updating drivers through the downloadcenter, and further self-rebooting the laptop, there was a problem with the screen blinking after logging in, which prevents me from doing anything, except for the ability to open the task manager !
AlHill
So the Intel support engineers can have more information about your system, Download, run, and save the results of this utility as a text file:
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility
Then ATTACH the text file using the instructions under the reply window ( Drag and drop here or browse files to attach ).
Kukisiki6665
I can't do anything, absolutely! All shortcuts on the desktop are gone. I can only open the task manager through the combination ctrl-alt-del, in this menu I can freely leave the system, change the user or open the task manager
Sebastian_M_Intel
Hello Kukisiki6665,
Thank you for posting on the Intel® communities.
For this behavior, I will appreciate if you can provide the following information:
1. Since you are not able to run the report, please provide:
  • Laptop's full model number:
  • Processor model number:
  • Operating System edition and version:
2. What is the exact driver version that was installed and caused this behavior?
3. Are you able to boot into Safe Mode? Please check this link for some guidance: https://support.microsoft.com/en-us/help/12376/windows-10-start-your-pc-in-safe-mode
4. Have you tried plugging an external monitor/TV and see if the issue persists there?
Note: Links to third-party sites and references to third-party trademarks are provided for convenience and illustrative purposes only. Unless explicitly stated, Intel® is not responsible for the contents of such links, and no third-party endorsement of Intel or any of its products is implied.
Sebastian M
Intel Customer Support Technician 
Sebastian_M_Intel
Hello Kukisiki6665,
Were you able to check the previous post and get the information requested? Please let me know if you need more assistance.
Sebastian M
Sebastian_M_Intel
Hello Kukisiki6665,
We have not heard back from you, so we will close this inquiry. If you need further assistance or if you have additional questions, please create a new thread and we will gladly assist you.
Sebastian M
