22892 Discussions
Life is Feudal You Own - Intel Core i7 6500U 3.1GHz - Graphics 520
FMore10
Buenos días:
Tengo el siguiente problema. Al jugar al Life is Feudal You Own, el juego comienza corriendo normalmente y luego empieza a verse muy pixelado. He actualizado el controlador a la versión 6709 y he seguido los consejos de la app de intel para el juego pero sigue sin solucionarse.
Saludos y espero su respuesta!
AlHill
Are you a laptop or desktop?
If a laptop, you should use only the drivers from the laptop manufacturer, and not the Intel drivers.
Doc
FMore10
Laptop... so I should not play using the HD Graphics 520? I'm sorry, not sure if I understood you..
AlHill
You should use the latest graphic driver(s) provided by your laptop manufacturer.
Doc
n_scott_pearson
Do not download graphics drivers from the Intel or NVIDIA/AMD sites. Use only those on your laptop manufacturer's site unless they specifically tell you that you can use those on the Intel site. The reason for this is because the graphics drivers are often modified by the manufacturer to support custom hardware features (dimming, focus adjustment, etc.) and, especially for dual graphics, switching between the graphics solution (for example, to support content protected media, where only the Intel driver provides license verification).
