22694 Обсуждение
Media players cannot automatically request Full(PC 0-255)/Limited(TV 16-235) YUV(8/10bit 4:2:0) range with "Applicattion Settings" Input Range selected in IntelHD Graphics Control Panel Force Full/Limited - RGB OK Applicattion Settings - Always Limited
ОКрав
Начинающий
4 596Просмотр.
W10 x64
Pentium G3258 win64_15.40.45.5126.zip
PotPlayer 1.7.18958
VLC media player 3.0.10
Media Player Classic-BE
Tests in .txt file
0 баллов
19 Ответы
Wanner_G_Intel
Модератор
4 459Просмотр.
Hello ОКрав,
Thank you for posting your question on this Intel® Community.
To better assist you, please provide us with the following information:
Generate a system report with the Intel® System Support Utility (Intel® SSU) and attach the report to this thread.
  1. Intel® SSU Download link
  2. Open the application and click on "Scan" to see the system and device information. By default, Intel® SSU will take you to the "Summary View".
  3. Click on the menu where it says "Summary" to change to "Detailed View".
  4. To save your scan, click on "Next", then "Save".
Generate a DxDiag* report and attach it.
  1. Go to Start > Run or Windows Key + R.
  2. On the Run prompt, type "dxdiag" then click OK.
  3. On the DirectX Diagnostic Tool window, click on Save All Information.
  4. Browse to a folder, type in a filename then click Save.
Please provide steps to replicate the issue. These steps are very crucial to finding the root cause and fix. A screenshot to illustrate the issue is a huge plus. A video of the failure is even better! Attach to the post or provide the YouTube link.
Wanner G.
ОКрав
Начинающий
4 459Просмотр.
what really useful information can be obtained from the logs?https://youtu.be/deG8X69JPqs
medeirosdez
Начинающий
4 459Просмотр.
You should (1st) have your display set to preferably RGB Full in Intel's Control Center (and your monitor/TV set to HDMI "high/extended/normal" black level, instead of "reduced/low"). (2nd) You should set video range in Intel's Control Center always as "Limited". There is no video material I know of that isn't "limited" (16-236) range. This way you should always get the correct brightness / contrast.
ОКрав
Начинающий
4 459Просмотр.
What is the functionality of the "Input Range: Applicattion Settings" option?
ОКрав
Начинающий
4 459Просмотр.
"There is no video material I know of that isn't "limited" (16-236) range."
I upload Lossless h.265 PC.709YUV444P8 from RGB https://youtu.be/deG8X69JPqs
but h.264 stream Rec709YUV420P8 from youtube compressed to TV
medeirosdez
Начинающий
4 459Просмотр.
Well, I can capture lossless RGB (full RGB, 0-255) from my PC also. The thing is, the moment YouTube does its multi format conversions, the video will be reencoded as YCbCr 4:2:0... The PC 0-255 range will necessarily become 16-236. If you're talking HDR content, then that is beyond the scope of my reply and I can't comment on the way it is handled. To put it simply, either by watching YouTube, Netflix, locally playing 1080p Bluray disks, DVDs, etc., the correct choice is "limited" under video settings, regardless of what you choose under display options.
Wanner_G_Intel
Модератор
4 459Просмотр.
Hello ОКрав,
Please retest the video settings using the Windows Movies & TV application. This one offers native support for most of our encoders/decoders.
If the issue can be seen on this application, please provide us with steps to reproduce this issue. This includes the key settings you are using on the applications.
Wanner G.
ОКрав
Начинающий
4 459Просмотр.
Windows Media Player does not display correctly under any settings
https://youtu.be/Eq3XFi4VV3M
ОКрав
Начинающий
4 459Просмотр.
I do not have the ability to install and test the "Windows Movies & TV application", maybe someone knows some portable analogue to check. What encoders and decoders are you talking about? You can make sure that the video is decoded correctly, the question is about the correct conversion "YUV-RGB" when using Direct3D 11 Video Renderer, the coefficients of which can be changed in the IntelHD Graphics Control Panel.
It is also not known how the color space is selected for conversion (BT.601, BT.709, BT.2020)
Wanner_G_Intel
Модератор
4 459Просмотр.
Hello ОКрав,
Please allow us to look into this issue.
Wanner G.
Wanner_G_Intel
Модератор
4 459Просмотр.
Hello ОКрав,
Are you able to provide us with the file you are using to reproduce this issue?
We would like know more information including the format of the video, etc
Wanner G.
ОКрав
Начинающий
4 459Просмотр.
ОКрав
Начинающий
4 459Просмотр.
Wanner_G_Intel
Модератор
4 459Просмотр.
Hello ОКрав,
Thank you for your response.
We will attempt to reproduce this issue.
Wanner G.
Wanner_G_Intel
Модератор
4 459Просмотр.
Hello ОКрав,
The full and limited option is working as expected. Unfortunately, we do not have a method to manually select the Color space used. This is being worked on and it will be introduced in a new version of Intel® Graphics Command Center. However, this is only compatible with 6th Generation Intel® Core Processors or newer.
No additional enhancements will be done for the Intel® Graphics Control Panel.
Wanner G.
Wanner_G_Intel
Модератор
4 459Просмотр.
Hello ОКрав,
If you need further assistance, please let us know. We will be glad to help you.
Wanner G.
Wanner_G_Intel
Модератор
4 459Просмотр.
Hello ОКрав,
We have not heard back from you, so we will close this thread. If you need further assistance, please start a new thread. We will be glad to help you.
Wanner G.
ОКрав
Начинающий
4 459Просмотр.
I plan to check everything after a clean installation of the operating system, drivers, players. The problem is still relevant, but it takes more time. What about calibrating the color of the display using ICC profiles? It's not easy to check because you need to reboot when applying a new profile, but you can only see the changes in real time.
Wanner_G_Intel
Модератор
4 459Просмотр.
Hello ОКрав,
The effect of this change varies based on the capabilities of the display. We were not able to reproduce the behavior you are experiencing.
Feel free to post an update related to this case as soon as you can.
Wanner G.
Ответить
