23848 Discussions
Missing Command Center Widget
Anthony8851
I checked my Gamebar and saw that intel Command Center is missing. The widget is also not shown on Microsoft's store.
Did I miss a notice that the widget is undergoing fixes, or is there an re-enabling option of some-kind in the application?
If possible, how do I get the widget back?
Sebastian_M_Intel
Hello Anthony8851,
Thank you for posting on the Intel® communities.
Please follow the instructions on this link to try to install the Intel® Graphics Command Center: https://www.intel.com/content/www/us/en/support/articles/000055840/graphics.html
If you are not able to get the tool with the steps above, please provide the following:
1. Run the Intel® System Support Utility (Intel® SSU) and attach the report generated:
  • Open the application, check the "Everything" box, and click on "Scan" to see the system and device information. By default, Intel® SSU will take you to the "Summary View".
  • Click on the menu where it says "Summary" to change to "Detailed View".
  • To save your scan, click on "Next", then "Save".
  • Use the option under the reply window to attach the report to the thread (Drag and drop here or browse files to attach).
2. By "widget" do you mean the Intel® Graphics Command Center actual tool or is it any specific feature of it?
3. Do you remember making any changes before the issue started? I.e. updating the driver, updating the Operating System version, etc.
4. Have you checked if the tool is installed in Apps and Features? Right-click on the Start button or press the Windows key + X keyboard combination. When the WinX menu opens, select Apps and Features.
Sebastian M
Intel Customer Support Technician
Sebastian_M_Intel
Hello Anthony8851,
Were you able to check the previous post and get the information requested? Please let me know if you need more assistance.
Sebastian M
Sebastian_M_Intel
Hello Anthony8851,
We have not heard back from you, so we will close this inquiry. If you need further assistance or if you have additional questions, please create a new thread and we will gladly assist you.
Sebastian M
