23468 Discussions
NPU driver finishes OK but Error 1000 is reported
PhugoidEffect
Like described in the subject, the end of the installation is reported as successful, but Driver & Support Assistant lists as "Installation failed with error code 1000"
Tried twice, same outcome.
PhugoidEffect
None of these worked. It's pretty obvious it was just a status error, the driver was correctly installed on the first try, but the reporting software wasn't correctly signaled.
In any event, I just followed someone's suggestion to ignore that specific driver and it somewhat solved the issue.
Andre46
I have the same problem.
Device Managemant screen
Intel Corporation   /    3-7-2025   /    32.0.100.4181
Intel driver & support History screen:
Intel NPU Driver - Windows
Description:
This download installs Intel® NPU Driver - Windows* 32.0.100.4181 for Intel® Core™ Ultra processors.
Version:
32.0.100. 4181
Release date:
July 23, 2025
Size:
117.58 MB
Regard, Andre
LT7879
I have the same problem too.
Anubis
same to me, err code 1000
MPG Z890I EDGE TI WIFI (MS-7E33)
285K
any soloution?
MarcoAuday
Today, 2025-07-24, I installed the new Intel NPU Driver but it produces error code 1000 immediately after my computer reboots. I tried reinstalling one more time with the same result. Also, the Intel Driver and Support Assistant keeps flagging the NPU as not installed.
My computer has an Intel Core Ultra 9 285k processor, ASUS ROG Maximus Apex Z890 motherboard, and I am running the latest Windows 11 with all the most recent updates applied.
About a week ago I was prompted to install the previous version of the NPU Driver and it was successfully installed the first time I tried.
skypjack
Same error. 285k on a MSI z890 tomahawk. Running latest and fully updated W11.
Tried to install, reinstall and clean install it. Nothing works apparently.
Frank90
Same error on ASUS ROG Strix Scar 18 with Intel Core Ultra 9 275HX. The issue is very wird, because the driver is already installed, but the manager says no.
And the updater points to the exact same version.
So here we are:
4 failures (1000 and 1006 error codes) for a driver that is installed in my OS, and the updater trying to install the exact same version into an infinite loop.
PD: Version 32.0.100.4082 had no issues when installing.
Passegua
Same problem, installed repaired three times. Same error
JedG_Intel
Hello PhugoidEffect,
It appears that you're having installation issues on NPU driver with Intel Driver & Support Assistant. To further troubleshoot the issue, kindly try to download the driver manually here -Intel® NPU Driver - Windows*
If you continue to observe the same issue, please let me know so we can further investigate.
Best regards
Jed G.
Dietmar-Po
I did that already without success. In addition I have removed all NPU drivers, installed npu_win_32.0.100.4082 and the new version afterwards, without success.
Frank90
Hello JedG_Intel. The driver is installed successfully (downloading the installer or using the assistant), but the assistant says the opposite. Please take a look at this:
As you can see, my PC already has the version 32.0.100.4181, but the assistant says that the installation fails:
And it also points to update it to the exact same version:
So, if it's installed, the issue is with the support assistant that cannot recognize the installed driver, or the driver is corrupt (i don't put my money on this).
MarcoAuday
Hi Jed G,
I downloaded the driver from the Intel website and manually installed it with the same result. Not knowing how important this driver is for the proper functioning of my computer I also downloaded the previous version (4082). After (4181) manual installation failed I manually forced the installation of (4082) and it was successful.
By the way, both failed installations of (4181) also generated messages in the Windows Events viewer:
Kernel-EventTracing, event ID: 2, Session "WindowsUpdate_trace_log" failed to start with the following error: 0xC0000035.
Hope this helps you solve this problem.
PhugoidEffect
Hello Jed,
Just like everyone else have reported, I have the very same issues. This is clearly a problem within the verification of the Assistant. The driver is installed just fine, a proof of that is the fact that when we try to reinstall, the installer detects it as Repair installation. Please advise the developers to take a look at the routine that verifies whether or not the installation has succeeded.
Thank you for your kind support.
SJH1016
Downloaded the driver manually and still get error 1000 message (tried with a clean installation too).
Passegua
Hi, I'm having the same problem. I hope Intel fixes it soon. I can't wait!
JohnnieBG
I'm suffering this error too.  It's very obviously a bug in this version as many people are suffering the same issue with many different configurations.
Please fix it for us!!!
BangIw
Driver Intel® NPU - Windows*
have try in manual or automatic aplication on my ideapad 5 pro ultra 9 185H
tommyr87
Glad I'm not the only one. I'm thinking my armor software was blocking it. Driving me crazy.
GMizusawa
Same problem as all others.
Both install methods result in Error 1006 or 1000 with ISDA reporting new driver available afterwards. Device manager indicates the driver was successfully updated.
Reinstall attempts permit "Repair" which indicates successful repair, only for the problem repeat.
ASUS Vivobook Pro 15 N6506MJ_Q543MJ +  Intel Core Ultra 9 185H
Sitearm
ditto result: driver details show driver present
ditto result: assistant keeps telling me I need to install (again)
ditto result: install program shows "repair"
ditto diagnosis from my POV: it is dsa failure to recognize completed install
gear: surrface pro 11 intel edition
functional impact: to be honest I have NO idea yet what an npu driver is supposed to be doing for me but I am trying to learn
webkostas
Hello, same error here. I noticed that when I was trying (repeatedly) to install the drivers, there was the following msg. Of course, there was no other installation going on, and I restarted numerous times too. It seems there is a generic issue/bug with those drivers. Let's hope they will solve and update soon.
