22680 Diskussionen
NZXT CAM CPU/GPU temps are N/A after installing ARC drivers.
Griffonlore
Anfänger
11.514Aufrufe
After installing my new ARC A-770 and installing the necessary drivers, NZXT CAM is no longer able to view the temps of my CPU or GPU. I'm also unable to change the fan speeds of my case and AIO while drivers are installed. I've installed previous driver versions and BETA drivers and it hasn't helped. I also uninstalled ARC Control to no avail. I've completely uninstalled and re-installed the drivers multiple times. And I've wiped the previous Nvidia drivers as well. I'm concerned about my cooling since CAM controls it and I don't want my CPU or GPU to overheat while the settings are dissabled.
16 Antworten
Carlos_L_Intel
Mitarbeiter
11.453Aufrufe
Hi @Griffonlore
Thank you for posting on the Intel® communities. I'm sorry for the inconvenience this might have caused you.
 In order to assist you, can you please help us with the following information:
  • Download and install the Intel®️ System Support Utility (Intel®️ SSU): https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows-  Open the application and select "Everything" click on "Scan" to see the system and device information. By default, Intel®️ SSU will take you to the "Summary View". Click on the menu where it says "Summary" to change to "Detailed View".  Click on "Next", save the report and attach it to your response.
  • If you remove the Intel® Arc™ A770 Graphics, do the features come back?
  • Any other changes besides uninstalling drivers and installing the Intel® Arc™ A770?
Carlos L.
Griffonlore
Anfänger
11.427Aufrufe
Hello Carlos,
I've attached the SSU file below as you requested.
Uninstalling the ARC GPU without uninstalling the drivers did restore CAM functionality. But re-installing it blocked the features again. And I've made no changes besides switching to the Arc A770. For context my previous GPU was an Nvidia GTX 1070.
LUci09
Einsteiger
11.416Aufrufe
I have the same problem
Carlos_L_Intel
Mitarbeiter
11.387Aufrufe
Hi @Griffonlore
Thank you for your reply. In this case, to ensure we have a completely clean installation of the drivers, please help me with the following:
  1. Download our latest released driver: https://downloadmirror.intel.com/774229/gfx_win_101.4255.exe
  2. Download Display Driver Uninstaller (DDU) software and extract the file.
  3. Open DDU ****.exe and run extract program.
  4. Reboot into Windows* safe mode. (Refer to Start your PC in safe mode in Windows.)
  5. Go to the DDU extract path and double-click the Display Driver Uninstaller.exe to open DDU.
  6. Click Close in the Options window.
  7. Select device type to GPU and select device to INTEL
  8. Click Clean and restart, wait the software to finish the process and auto reboot Windows to the normal mode.
  9. Install the previously downloaded driver.
Carlos L.
LUci09
Einsteiger
11.349Aufrufe
hello already done it does not solve the problem
Griffonlore
Anfänger
11.308Aufrufe
Hi Caros,
Using DDU to uninstall and re-install the intel drivers unfortunately didn't fix the issue.
Carlos_L_Intel
Mitarbeiter
11.283Aufrufe
Hello @Griffonlore, @LUci09
Carlos L.
Carlos_L_Intel
Mitarbeiter
11.163Aufrufe
Hi @LUci09,
Thank you for your time. In this case, the incompatibility is on NZXT CAM's side, our recommendation is to reach app developer.
Carlos L.
LUci09
Einsteiger
11.157Aufrufe
hello @Carlos_L_Intel  it's not only with nzxt the problem is also on icue and Armory Crate
Carlos_L_Intel
Mitarbeiter
11.133Aufrufe
Hi @LUci09
 Thank you for your post. Does the same exact thing happens in both iCUE and Armory Create?
Carlos L.
LUci09
Einsteiger
11.129Aufrufe
Carlos_L_Intel
Mitarbeiter
11.093Aufrufe
Hi @LUci09,
 Thanks for the heads-up. Let me check some information internally again and I will post back with more details soon.
Carlos L.
Carlos_L_Intel
Mitarbeiter
11.061Aufrufe
Hi @LUci09,
Thank you for your time. If you look at the information using Intel Arc? Is it reporting correctly?
Carlos L.
LUci09
Einsteiger
11.057Aufrufe
hello @Carlos_L_Intel  in arc control graphics card info is ok
Carlos_L_Intel
Mitarbeiter
10.920Aufrufe
Hi @LUci09
Thank you for the information. In this case, as long as Arc Control displays the information correctly, the issues with 3rd party tools would need to be addressed by the app developer.
Carlos L.
Carlos_L_Intel
Mitarbeiter
10.612Aufrufe
Hi @LUci09,
We have not heard back from you, so we will close this thread. If you need any additional information, please submit a new question, as this thread will no longer be monitored.
Carlos L.
Antworten
